70 challenger alignment #1262052
07/05/12 11:18 AM
07/05/12 11:18 AM
Harrisburg Pa. 17112
moparmikethree Offline OP
Im doing an alignment on my 70 challenger with a 360.I want to set it up to be very stable at high way speeds, or at the strip.
what readings should I go for. and would more/less caster or camber be best
Re: 70 challenger alignment [Re: moparmikethree] #1262053
07/05/12 12:13 PM
07/05/12 12:13 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
You want as much positive caster as possible.Camber about 1/2.Toe I set at about .10 total.Usually you cant get much pos caster without offset bushings.Every car differs though.My 65 I had about 5 degrees neg caster.With the offset bushings I have about .6 positive.I did mine at work on our alingment machine.Rocky
Chrysler Firepower
