Hog ring pliers... #125783
09/24/08 06:20 PM
09/24/08 06:20 PM
NORTHERN VA
THESHAKERPROJECT Offline OP
NORTHERN VA
Who sells a good set of hog ring pliers ?? Are the Eastwood ones any good ?? I would like a good set that will last. Also do you need the pulling pliers to do seat covers ??Im gonna try to do the rear seats of my Challenger.
Re: Hog ring pliers... [Re: THESHAKERPROJECT] #125784
09/24/08 06:23 PM
09/24/08 06:23 PM
Tampa Florida
MoparTod Offline
MoparTod  Offline
Tampa Florida
I only use the hog ring pliers when doing it. I have no problem with the cheap set we have at work. I work for a used car dealer and we have to remove seat covers alot to wash them. You can pick them up on ebay for as little as ten dollars. Eastwoods is likely to be better. Try legendary also. Tod
Re: Hog ring pliers... [Re: THESHAKERPROJECT] #125785
09/24/08 06:43 PM
09/24/08 06:43 PM
LENOX , MI
KMPX2 Offline
mopar addict
KMPX2  Offline
mopar addict
LENOX , MI
HD wire cutters to cut the old clips
Re: Hog ring pliers... [Re: KMPX2] #125786
09/24/08 06:48 PM
09/24/08 06:48 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
bought a set of hog ring pliers from lengedary when i bought the first set of seat covers...just used the again to do another set of seat covers last weekend...boy...bucket seats are fun...LOL
says made in usa on them too...
Tony
70 AARCuda Vitamin C
Re: Hog ring pliers... [Re: 70AARcuda] #125787
09/24/08 08:09 PM
09/24/08 08:09 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
The spring loaded hog ring pliers are much easier to use than the standard type.
It helps to hold the ring in the pliers when you dive in the foam to hook the rings.
Re: Hog ring pliers... [Re: sthemi] #125788
09/24/08 09:33 PM
09/24/08 09:33 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
They also make a cutter for removing old rings which works way better than a set of side cutters. These came from Miami Products here in town.
Re: Hog ring pliers... [Re: Challenger 1] #125789
09/25/08 12:51 AM
09/25/08 12:51 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Should be able to get both the pliers and cutters from your local fabric store. I did. Just like the ones pictured above.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Hog ring pliers... [Re: moparmarks] #125790
09/25/08 11:20 PM
09/25/08 11:20 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
I bought mine at the local farm and ranch outlet. Dirt cheap and have been used on 3 sets of seats so far. Spring loaded also.
Re: Hog ring pliers... [Re: Posest] #125791
09/26/08 07:03 PM
09/26/08 07:03 PM
Airville Pa.
boomer Offline
boomer  Offline
Airville Pa.
Bought my pliers at the local NAPA store. They look just like the ones previously pictured. I didn't use any stretchers to install my seat covers. If the covers seem small, use a hair dryer to warm the cover up and it will stretch a little better.
