426 Hemi flywheel are their 2 diff. 172 flywheels? #1256567
06/24/12 05:57 PM
06/24/12 05:57 PM
N.Y.
sixpacksteve Offline OP
N.Y.
i have a new hayes 11 in clutch with a 8 bolt 172 teeth flywheel, and a 512 cast bell. the bell will not fit. did they make 2 different ones?
Hell Hath No Fury Like Mine
Re: 426 Hemi flywheel are their 2 diff. 172 flywheels? [Re: sixpacksteve] #1256568
06/24/12 08:38 PM
06/24/12 08:38 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I only see one listed in my white book , what is not fitting ?
Re: 426 Hemi flywheel are their 2 diff. 172 flywheels? [Re: JohnRR] #1256569
06/24/12 10:14 PM
06/24/12 10:14 PM
N.Y.
N.Y.
the flywheel looks to be too far back from the engine, and wont allow the bell to fit on the engine, the part on the flywheel isn't flush where it bolts to the flywheel like a 440, it flairs about an inch more off the engine. did they make one for a 413?
Re: 426 Hemi flywheel are their 2 diff. 172 flywheels? [Re: sixpacksteve] #1256570
06/24/12 10:16 PM
06/24/12 10:16 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
WAG - there are 8-bolt 413 industrial cranks that protrude out past the rear surface of the block
Re: 426 Hemi flywheel are their 2 diff. 172 flywheels? [Re: 6bblgt] #1256571
06/24/12 10:25 PM
06/24/12 10:25 PM
N.Y.
N.Y.
i have a 426 hemi crank, then this would have to be a 413 flywheel!
Re: 426 Hemi flywheel are their 2 diff. 172 flywheels? [Re: sixpacksteve] #1256572
06/25/12 12:00 AM
06/25/12 12:00 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
They also made 172 tooth flywheels for trucks that has a step register on them. IF you want I can take a picture for comparo.
Re: 426 Hemi flywheel are their 2 diff. 172 flywheels? [Re: Jeremiah] #1256573
06/25/12 05:45 AM
06/25/12 05:45 AM
N.Y.
N.Y.
that would be great! thanks
