Page 4 of 4 1 2 3 4
Re: Dynomax Super Turbo Mufflers.! [Re: Tom Hand] #1254765
07/01/12 11:52 AM
07/01/12 11:52 AM
Milwaukee, WI
Prince_Valiant Offline
Milwaukee, WI
I've got the dynomaxes on the LRT....
It's a trick little exhaust...3" from the headers back, to an x-pipe, then 3" up and out, all mandrel bent.
I just had some work done by a local mopar shop and the owner went out of his way to tell me how much he loved the sound the exhaust makes...
It's loud enough to command attention in a parking lot driving around, but reasonable enough while driving/low throttle...but step on it and it gets impressively loud!
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph
1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD)
1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD)
1989 Shelby CSX #500/500
Re: Dynomax Super Turbo Mufflers.! [Re: Tom Hand] #1254766
07/01/12 12:32 PM
07/01/12 12:32 PM
Maryville tn
67coronetman Offline OP
Maryville tn
Nice i would love to hear a set of the longer ones and see the differance i have a friend building a 572 stroker Hemi i think he is looking at those.!
On the same engine with everything the same, the 20" case Super Turbos measured about 2 dBA at idle and 3 to 5 dBa less at higher engine speeds, all at static conditions. Under load is slightly different but the 20" case version is most definitely quieter and less prone to drone.
Even though they are quieter, they allow as much air to pass through due to the longer internal sections that enable the air to smooth out after the flow reversal (my theory anyway).
Tom
Old car are me......
Re: Dynomax Super Turbo Mufflers.! [Re: Prince_Valiant] #1254767
07/01/12 12:34 PM
07/01/12 12:34 PM
Maryville tn
Maryville tn
Mandrel bent pipes that is what i want on my next motor 493 Stroker!
Re: Dynomax Super Turbo Mufflers.! [Re: 67coronetman] #1254768
07/01/12 01:36 PM
07/01/12 01:36 PM
MO, USA
Tom Hand Offline
Tom Hand  Offline
MO, USA
67, he needs to look at the larger case versions (5" by 11" with 3" inlet and outlets) if he can still find them. The smaller cases ones (~4.75" by 10.25") with only 2.5" inlet and outlet bushings will have a tough time flowing enough exhaust gas to make the engine happy at higher loads and rpms.
Need a part number? 17769 is the offset center version that will fit the Hemi-powered car.
Tom
Re: Dynomax Super Turbo Mufflers.! [Re: Tom Hand] #1254769
07/01/12 09:18 PM
07/01/12 09:18 PM
North Central Florida
E
eightlitermopar Offline
E
I have the walker exhaust 17749 on my daily driver grandma coronet, but it's just a mild 318. It's pretty quiet. I believe they are the same as the dynomax and a lot cheaper.
Anyway, here is a chart I got off moparts a while ago. I will be changing my flowmasters to these on my 383 RR. I love the flowmaster drone when driving alone, but you can't talk to anyone in the car.
Mopar or no car
Re: Dynomax Super Turbo Mufflers.! [Re: Tom Hand] #1254770
07/01/12 09:20 PM
07/01/12 09:20 PM
Maryville tn
Maryville tn
Nice i will pass on the info.!
Re: Dynomax Super Turbo Mufflers.! [Re: 67coronetman] #1254771
07/01/12 11:17 PM
07/01/12 11:17 PM
MO, USA
Tom Hand Offline
Tom Hand  Offline
MO, USA
You mean my charts from a few years ago? :)
For information, the bottom three are Magnaflow mufflers so the data is directly relatable to the current offerings.
Re: Dynomax Super Turbo Mufflers.! [Re: 67coronetman] #1254772
07/01/12 11:31 PM
07/01/12 11:31 PM
Milwaukee, WI
Milwaukee, WI
A quick vid idling a light revving.
http://www.youtube.com/watch?v=0WnwQsji3Qs
Re: Dynomax Super Turbo Mufflers.! [Re: Tom Hand] #1254773
07/02/12 12:23 AM
07/02/12 12:23 AM
E
E
that would be the one
I have referred to it many times!
eightlitermopar
Mopar or no car
Re: Dynomax Super Turbo Mufflers.! [Re: 77ProStreet] #1254774
07/02/12 06:29 PM
07/02/12 06:29 PM
NEW HAMPSHIRE AND MAINE
BIGSTROKER Offline
BIGSTROKER  Offline
i use to like the super turbos until i tried a set of the dynomax ultra flows now thats a muffler!
Re: Dynomax Super Turbo Mufflers.! [Re: Prince_Valiant] #1254775
07/02/12 11:32 PM
07/02/12 11:32 PM
Maryville tn
Maryville tn
Sweet sounding truck very cool.!
Re: Dynomax Super Turbo Mufflers.! [Re: 67coronetman] #1254776
07/02/12 11:35 PM
07/02/12 11:35 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
I just use some cheap summit ' bullit racing mufflers ' in conjunction with whatever muffler I'm using at the time. Old trick to eliminate drone.. just my
When it takes more than a sweet mullet to prove you rule at the trailer park..
Page 4 of 4 1 2 3 4
