Page 3 of 3 1 2 3
Re: How do you adjust pinion angle? [Re: 98 SNAKE EATER] #1254316
02/19/14 04:31 PM
02/19/14 04:31 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Its simple. Shim the trans to get its centerline level at 0 degrees and then shim the rear to the downward degrees you want to run from 2 to 7 down. I always like to get the trans level at 0 first if I can and then once the rear (pinion) centerline is level you know to nose it down to the degrees you want. Myself I feel its easier for most to work with it if the trans centerline is 0. Ron
Re: How do you adjust pinion angle? [Re: 383man] #1254317
02/20/14 01:17 PM
02/20/14 01:17 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Agreed.............I even pm`d him w/my number so I could walk him through it but so far no response............ Hope he figures it out............
Re: How do you adjust pinion angle? [Re: 383man] #1254318
02/20/14 02:06 PM
02/20/14 02:06 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Whats the easiest way to make sure you've got the centerline of the trans with it installed in the car?
Re: How do you adjust pinion angle? [Re: GTX MATT] #1254319
02/20/14 03:11 PM
02/20/14 03:11 PM
USA
540DUSTER Offline
540DUSTER  Offline
USA
measure the damper or front pulley,then subtract 90 degrees
Re: How do you adjust pinion angle? [Re: 540DUSTER] #1254320
02/20/14 04:15 PM
02/20/14 04:15 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Page 3 of 3 1 2 3
