Max Lift With Stock Heads
#1253524
06/19/12 02:00 AM
06/19/12 02:00 AM
Posts: 5,163 CT
GTX MATT
CT
What is the max lift you can run with stock heads without machining the guides? What is the correct procedure for checking this?
Re: Max Lift With Stock Heads
[Re: Cab_Burge]
#1253528
06/19/12 04:21 PM
06/19/12 04:21 PM
Posts: 5,163 CT
GTX MATT
CT
They are from a non-HP engine but the springs and retainers will be aftermarket. I'm just worried about clearance between the guide/valve steam seal and the retainer. I'm looking at about .500 lift. I haven't bought a cam yet, I'm trying to figure everything out before I buy one and find out it wont work.
The old DC 509s never causes any issues did they?
[Re: GTX MATT]
#1253529
06/19/12 06:04 PM
06/19/12 06:04 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I ran a voodoo cam with .533 lift with stock heads with different springs worked good. I changed to a .550 lift voodoo cam and used the same springs and wouldnt rev over about 5800 so im assuming I had some issues there.
67' charger 499 RB
10.57 at 127
[Re: lewtot184]
#1253533
06/19/12 11:38 PM
06/19/12 11:38 PM
Posts: 5,163 CT
GTX MATT
CT
I plan to check it, what I'm asking is SHOULD it be safe with something like the 509, just over .500 lift? You know, before I buy the cam, check, find out it wont work, and have to get another cam.
