Re: Brake Drum Thickness
[Re: B1arno]
#1251606
06/15/12 06:39 PM
06/15/12 06:39 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
It was off an internet search from a part reseller... Allowing a .090 oversize leads to brake shoes that are practically worn out before the lining makes full contact with the drum... The equipment to arc shoes doesn't get used anymore do to health concerns so if you throw standard shoes on a O/S drum only the center of the shoe makes contact..... Even at .060 O/S it's a long time before the rear brakes are effective...
Description DRUM SPEC Specifications for Brake Drums Display Value (mm or inch) mm Max Diameter mm 280.924 Max Diameter inches 11.06 Outer Diameter mm 346 Outer Diameter inches 13.62 Height mm 112.78 Height inches 4.440 Nominal Diameter mm 279.40 Nominal Diameter inches 11.00 Friction Surface mm 74.42 Friction Surface inches 2.93 Hub Hole / Register mm 71.88 Hub Hole / Register inches 2.83 Stud/Bolt Hole Diameter mm Stud/Bolt Hole Diameter inches .650 Number of Holes/Studs 5 Stud/Bolt Circle Diameter mm 114.3 Stud/Bolt Circle Diameter inch 4.50 Weight in lbs (Including box) 23.00 Mounting Type Floating Application CHR Per Car Quantity 2
