Stock SB Timing Cover thickness? #1247571
06/09/12 12:19 AM
06/09/12 12:19 AM
Out West
408strokerdart Offline OP
Out West
Can someone check the thickness of a stock timing cover? Pretty accurate measurement is needed...better than just a tape measure if possible. Thanks! All I have here is the short deck Arrow cover and they are not as deep as a stock one.
Re: Stock SB Timing Cover thickness? [Re: 408strokerdart] #1247572
06/09/12 01:02 AM
06/09/12 01:02 AM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
I got 2.53
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: Stock SB Timing Cover thickness? [Re: 440W8 Duster] #1247573
06/09/12 01:08 AM
06/09/12 01:08 AM
Out West
Out West
I calculated 2.56, just looking for other numbers to back them up. Anyone else help us verify this?
Re: Stock SB Timing Cover thickness? [Re: 408strokerdart] #1247574
06/09/12 09:05 AM
06/09/12 09:05 AM
BPE Offline
BPE  Offline
I just went out out and measured a couple I have here. One is 2.486", the other one is 2.495". I also took a measurement of one on an assembled engine and got 2.522" but you would have to account for the compressed thickness of the .030" timing cover gasket. Hope this helps.
Rod
Re: Stock SB Timing Cover thickness? [Re: BPE] #1247575
06/09/12 11:44 AM
06/09/12 11:44 AM
Out West
Out West
Thanks Guys. Looks like a nominal thickness of 2.50 with a pretty big tolerance allowance.
Re: Stock SB Timing Cover thickness? [Re: 408strokerdart] #1247576
06/09/12 12:04 PM
06/09/12 12:04 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Just measured three brand new covers....all 2.496
RIP Monte Smith
Re: Stock SB Timing Cover thickness? [Re: CompWedgeEngines] #1247577
06/10/12 12:56 AM
06/10/12 12:56 AM
Out West
Out West
Thanks. That gives me even more confidence in the 2.500 nominal dimension.
