2009 Dodge Ram 1500 5.7 HEMI Engine Noise #1245986
06/05/12 10:43 PM
06/05/12 10:43 PM
NB, Canada
Deaner Offline OP
Deaner  Offline OP
NB, Canada
Hey would any of you know what I can do to help or stop my Hemi from ticking? only on the passenger side.. Some say it's the manifold, some say it's my valves and as far as just being a oil problem. I'm running a 5W30 full synthetic. Any info would be great Thanks...
Re: 2009 Dodge Ram 1500 5.7 HEMI Engine Noise [Re: Deaner] #1245987
06/06/12 07:22 AM
06/06/12 07:22 AM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
Check your exhaust manifold studs, usually the rear studs will break.
Re: 2009 Dodge Ram 1500 5.7 HEMI Engine Noise [Re: teflon] #1245988
06/06/12 03:31 PM
06/06/12 03:31 PM
P
Paul_Fancsali Offline
P
A guy at the Dodge dealer I talked to told me everyone he hears clicks. Valve spring breakage is another issue
Re: 2009 Dodge Ram 1500 5.7 HEMI Engine Noise [Re: Paul_Fancsali] #1245989
06/06/12 04:08 PM
06/06/12 04:08 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
On a buddies 2010, he heard a noise and took back to dealership. They went through all kinds of stuff, but finally came down to the "noise reducing sleeves" that are around the valve springs. They are too tight and springs would rub on the sleeves, making the noise. Apparently earlier 5.7's didn't have these ?? Or had more clearance on them ??? Not sure, but check with your dealership . . .
Cheers
Mark
Re: 2009 Dodge Ram 1500 5.7 HEMI Engine Noise [Re: teflon] #1245990
06/09/12 11:34 PM
06/09/12 11:34 PM
NB, Canada
Deaner Offline OP
Deaner  Offline OP
NB, Canada
Thanks for the tip it is what im expecting the problem to be!!! Any idea if seafoaming my oil is good and is it the same can to seafoam my gas? and if so how do i do that?
Re: 2009 Dodge Ram 1500 5.7 HEMI Engine Noise [Re: Deaner] #1245991
06/10/12 04:37 AM
06/10/12 04:37 AM
Middle of A Field
O
OrangeProwler Offline
O
Middle of A Field
Okay I've owned two 5.7L Hemi trucks and I will tell you that they all tick due to the valvetrain geometry and setup. If you have a really loud tick that is pronounced when cold and it goes away after fully warming up then you probably have a broken exhaust manifold bolt. The OEM ones stink so it is broken I would try to see if ARP has some good quality ones. Other than that both of my trucks ticked via the valvetrain and I ran Mobil filters with their synthetic oil.
On a 2009 I wouldn't seafoam the engine or the fuel system.
