1969 B-body with a/c - heater control vacuum switch ? #1245399
06/04/12 05:34 PM
06/04/12 05:34 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Well.
I have the vacuum switch back out for too hard to push buttons and thought I better fit it while the dash is out,
Anyway, the switch in the car has an electrical pigtail soldered on the terminals.
the NOS switch I have here does not.
Can I just un-solder the old wiring and solder it into the new switch or are the switches themselves different internally ?
anyone done it
Re: 1969 B-body with a/c - heater control vacuum switch ? [Re: gtx6970] #1245400
06/04/12 07:32 PM
06/04/12 07:32 PM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
These 5 wires? I removed from old switch with soldering gun, cleaned up connections, put shrink wrap on and soldered on to new switch. Key is to tin wire ends, flux well and have a hot tip and solder at the ready to as not to build up to much heat.
