Is a Purple cam, standard bore, 340power brake friendly #1244925
06/03/12 07:52 PM
06/03/12 07:52 PM
eastern, pa.
cudabitten Offline OP
eastern, pa.
Does a 340 with Purple cam, have at least 14-16 inches of vacuum for power brakes?
Standard bore with a hone and re-ring.
Re: Is a Purple cam, standard bore, 340power brake friendly [Re: cudabitten] #1244926
06/03/12 07:56 PM
06/03/12 07:56 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
Lotsa purple cams to choose from. Which one?
Re: Is a Purple cam, standard bore, 340power brake friendly [Re: cudabitten] #1244927
06/03/12 07:57 PM
06/03/12 07:57 PM
Northeastern PA
Fanning Offline
Fanning  Offline
Northeastern PA
Re: Is a Purple cam, standard bore, 340power brake friendly [Re: formula_s] #1244928
06/03/12 07:58 PM
06/03/12 07:58 PM
eastern, pa.
eastern, pa.
Never knew that....I thought a Purple cam was a Purple cam. The numbers are, duration 282, lift 484.
Re: Is a Purple cam, standard bore, 340power brake friendly [Re: cudabitten] #1244929
06/03/12 08:01 PM
06/03/12 08:01 PM
warfordsburg, PA
dirt Offline
dirt  Offline
warfordsburg, PA
probably be ok , any larger like the 508 and you would probably have problems, i have a 440 with the 484 but i dont have power breaks so its just my guess.
Re: Is a Purple cam, standard bore, 340power brake friendly [Re: dirt] #1244930
06/03/12 08:11 PM
06/03/12 08:11 PM
eastern, pa.
eastern, pa.
Thank you, I did call CompCam tech support. Guy there said I should be OK,but I wanted to check with Moparts Guys...
Re: Is a Purple cam, standard bore, 340power brake friendly [Re: cudabitten] #1244931
06/03/12 09:03 PM
06/03/12 09:03 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
14 inches with a 484, probably not.
Re: Is a Purple cam, standard bore, 340power brake friendly [Re: RobX4406] #1244932
06/03/12 09:09 PM
06/03/12 09:09 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
the 284-484 wont make enough vacuum for power brakes. Its 248* @.050" and ground on a tight 108 lsa.
Re: Is a Purple cam, standard bore, 340power brake friendly [Re: RobX4406] #1244933
06/03/12 09:12 PM
06/03/12 09:12 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
I ran the old 284/.484 purple shaft in a basically stock 383 and it only had about 13" at idle.
Re: Is a Purple cam, standard bore, 340power brake friendly [Re: AdamR] #1244934
06/03/12 09:27 PM
06/03/12 09:27 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
284/484 is 241* at .050
292/508 is 248* at .050
Tony
70 AARCuda Vitamin C
Re: Is a Purple cam, standard bore, 340power brake friendly [Re: 70AARcuda] #1244935
06/03/12 09:40 PM
06/03/12 09:40 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
What is your goal? I run the Purple shaft 268/272 .450/455 cam in my 340 under a 6 pac in my 81 shorty. I have power brakes. This cam has a sweet lope at idle, good power and the fuel mileage is great. If your after a street can I wouldnt go bigger than the 280/474.
I am truckless..
Re: Is a Purple cam, standard bore, 340power brake friendly [Re: 70AARcuda] #1244936
06/03/12 09:45 PM
06/03/12 09:45 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Is that advertised or measured ? I think someone here measure a 484 and a 509 and came up with 248* and 254* respectively.
Re: Is a Purple cam, standard bore, 340power brake friendly [Re: DrCharles] #1244937
06/03/12 10:05 PM
06/03/12 10:05 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
I run that cam in my super bee. with initial timing set at 20 w/38 total i have 15 inches of vac plenty for my brake booster. I run the big Voodoo 513/533 in my GTX timing set 21 initial w/38 total that has no problem with power brakes either. They both have poor vac when timing is set low. Both like the higher initial timing.
Re: Is a Purple cam, standard bore, 340power brake friendly [Re: AdamR] #1244938
06/03/12 10:13 PM
06/03/12 10:13 PM
eastern, pa.
eastern, pa.
Thanks everyone.... I'm not sure what these other numbers mean, but it sounds like this engine would need a different cam to be used with my power brakes.
I did not buy it yet, but if I do, I guess I need a cam with less than 450 lift. Right?
I know very little about this stuff other than I want a stockish 340 in my Cuda and I want to retain my power brakes.
Re: Is a Purple cam, standard bore, 340power brake friendly [Re: cudabitten] #1244939
06/03/12 10:22 PM
06/03/12 10:22 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Smaller duration is what you are after for more vac. The lift isnt the problem.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Is a Purple cam, standard bore, 340power brake friendly [Re: AdamR] #1244940
06/03/12 11:19 PM
06/03/12 11:19 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
There are (2) 284-484 cams..
The older version #P4120231 has significantly more overlap (68) and delivers less vacuum..
The later version #P5007696 has an overlap of 56 and delivers higher vacuum along with better driveability..
Don't use the #P4120231 if you have power brakes..
Just my $0.02..
Re: Is a Purple cam, standard bore, 340power brake friendly [Re: AdamR] #1244941
06/03/12 11:51 PM
06/03/12 11:51 PM
IN
ahy Offline
ahy  Offline
IN
Agree... much over 230 to 235@ .050 in a 340, especially with tight LSA, isn't going to make enough vacuum for PB.
One member mentioned a lower duration purple shaft that would likley work, there are other options. What are your goals?
Re: Is a Purple cam, standard bore, 340power brake friendly [Re: Sinitro] #1244942
06/04/12 12:37 AM
06/04/12 12:37 AM
Lake Elmo, MN
Evil Monkey Offline
Evil Monkey  Offline
Lake Elmo, MN
I've got a 284-484 purple shaft in my 360, probably the older version since I built the motor in 1995 (but I'm not sure since I don't know when the newer version came out). My power brakes work fine, but I've got a vacuum reservoir. Without the reservoir, I don't think they would work well at all.
1974 'Cuda 360/TKO 1990 Ram Van 1998 Neon
Re: Is a Purple cam, standard bore, 340power brake friendly [Re: Evil Monkey] #1244943
06/04/12 01:26 AM
06/04/12 01:26 AM
Tempe, AZ
loco340cuda Offline
loco340cuda  Offline
Tempe, AZ
I've got the MP484 cam (108LSA version) in a 340 stroker (417ci) and I get about 14" of vacuum. I have power brakes and no issues.
70 Cuda 340 4 speed - now stroked to 416ci (SOLD)
2017 Mustang Shelby GT350
Re: Is a Purple cam, standard bore, 340power brake friendly [Re: loco340cuda] #1244944
06/04/12 08:49 AM
06/04/12 08:49 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
the 4" stroke makes a huge difference.
