Re: video tease.
[Re: hemi-itis]
#1243563
06/02/12 10:47 AM
06/02/12 10:47 AM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Tease alright,not even a little GOOSE
I know!if the ATF was not spraying all over the floor i would have let the parts get warm and blipped it for ya.I spliced the trans line togather untel i get a cooler and will try again today to check the fluids and any leaks and my A/F from drilling out the int circuit in the carb for more fuel.
Re: video tease.
[Re: racer_amx]
#1243565
06/02/12 02:49 PM
06/02/12 02:49 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
Re: video tease.
[Re: Guitar Jones]
#1243566
06/02/12 05:08 PM
06/02/12 05:08 PM
Clanton
northern,Ohio,USA
Well she got up to temp but the temp gauge is not working[mechanical]i must have pinched the line so i will need to swap out that for an EGT probe,new gauge,trans temp gauge.The neutral safety wire came off the relay and a plug wire was not all the way on the #8 plug so now i can move on to other things.[Idle rpm/mix,start watching the LM-1/LC-1,put a Y fitting in the intercooler line[supply side]and start tunning for that A/F so it will stay running with just tap water running.I dont want to PO the neighbors so that is it untel monday for vids.If you have a question just ask. http://www.youtube.com/watch?v=c6POMQLjbpM
