Re: what effect does taller tire have on gear ratio?
[Re: frank]
#124341
09/22/08 10:48 AM
09/22/08 10:48 AM
Posts: 21,823 Kirkland, Washington
Pacnorthcuda
If putting a taller tire on a vehicle than stock, will that have an effect on gear ratio? So would putting a taller tire on make a car or truck with a 3:55 act like a 3:28? Would this result in better MPG?? Is there a calculator for this?? Thanks
Short answer: yes. You can calculat it from your starting point: Lets say you have 26" tires and 3.55 gears, and you're contemplating moving to a 28" tire. 26 x pi = 81.7" 28 x pi = 88.0" thats a 7.7% difference. (100-7.7) = 92.3 .923 (cause we're dealing with percentage) x 3.55 = 3.28
So a change from 26 to 28 in tire diameter would have the effect of going from a 3.55 gear to a 3.28. (some rounding error is present in the above exampple...but you get the idea)
[Re: Pacnorthcuda]
#124342
09/22/08 10:53 AM
09/22/08 10:53 AM
Posts: 1,195 Snowing in the north!
Dart 340
moparts member
moparts member
Yep, you could do that or just use this cool widget. http://vexer.com/68rt/speed.html
[Re: frank]
#124343
09/22/08 05:00 PM
09/22/08 05:00 PM
Posts: 2,138 tucson az
frank
tucson az
