Rear Suspension Noise #1241714
05/29/12 11:37 AM
05/29/12 11:37 AM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Well Ive got about 250 miles on the Cuda now. She is running sweet. One issue I have is I'm continuing to have a rubber sqeaking sound when I hit a pot hole or go over a speed bump in the rear suspension. Iv'e checked tightened the rear shock bolts and now Im down to the leaf spring attach points new rubber. Im curious if anyone else has had this issue and short of taking it back apart is there a solution to this problem? I guess im looking for an easy fix or someones prior experiences for resolution? Thanks
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: Rear Suspension Noise [Re: 19cuda73] #1241715
05/29/12 11:44 AM
05/29/12 11:44 AM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
Did you use Urethane bushings? If you did not use the lube supplied they do squeak.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: Rear Suspension Noise [Re: Savoy1964] #1241716
05/29/12 12:06 PM
05/29/12 12:06 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
No I thought of that too so I checked my reciepts and they are just the Rock Auto Rubber ones.
1972 Corvette
