Popping/Knocking noise from motor when 4 bbl kicks in #1241626
05/29/12 09:05 AM
05/29/12 09:05 AM
Michigan, USA
Bucky Offline OP
Bucky  Offline OP
Michigan, USA
when I stomp on the gas the motor tends to mis fire pop and knock. Other than that it runs fine. any ideas.
Re: Popping/Knocking noise from motor when 4 bbl kicks in [Re: Bucky] #1241627
05/29/12 09:23 AM
05/29/12 09:23 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
sounds like not enough gas or your timings way off.check for vac. leaks.
