rear wheel cylinders #1241367
05/28/12 09:52 PM
05/28/12 09:52 PM
middleburg,fl
barryv Offline OP
barryv  Offline OP
middleburg,fl
hi, i thought i once read about improved rear wheel cylinders for mopars. i have a 1972 barracuda with power brakes. it has disc up front and drums in rear. i have always had a low spongy pedal no matter what i have tried.any help would be appreciated.thanks
Re: rear wheel cylinders [Re: barryv] #1241368
05/29/12 11:22 AM
05/29/12 11:22 AM
I would spoon up the rear linings then bleed the M/C then all 4 corners in order & see where you're at
