Hemi engine performance #1241364
05/28/12 09:51 PM
05/28/12 09:51 PM
rpsrpsmopar Offline OP
My CUDA Hemi clone runs fine when I first take it out for a drive. After several miles especially on a hot day it will stall out. Once I let it set for 10-15 minutes it will start up and run fine for a while, however after several miles it stalls out again. Does any one know my problem? Thanks......
Re: Hemi engine performance [Re: rpsrpsmopar] #1241365
05/28/12 09:55 PM
05/28/12 09:55 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
depending on ignition system used sound like a ignition module.
BUT ??
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Hemi engine performance [Re: rpsrpsmopar] #1241366
05/28/12 11:25 PM
05/28/12 11:25 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Maybe its vapor locking. Fuel lines close to headers, no return line etc, can cause our ethanol laced pump gas to boil at a lower.temp. My hemi had similar symptoms during hot summer months. Shaker base kept the heat in tbe lines too. Return line with vapor separator solved tbe problem. Just a thought.
