Hughes based 426 S.B. dyno test
#1240628
05/27/12 09:25 PM
05/27/12 09:25 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
Jim (DemonDuster) asked me to test his engine he has on here for sale. He was asked what kind of power it put out. The build is a Hughes Engines 426 shortblock based on a 360 L.A. block.(4.03 boreX 4.180 stroke) Hughes also installed one of their hydraulic street grinds,HEH 3237AL. Jim installed a set of OOTB Edelbrock RPM heads with Hughes 1.5 rockers and deep port matched Victor intake. I used one of my shop carbs,an HP 950 that is set up just rich enough to be safe for testing. I also used a set of my headers,Hooker Super Comp 1 3/4 X 3". I honestly estimated 530 lbs-ft and 450 hp with some tuning. It idles with 14-15"of vacuum and sounds really tame. I set the timing for the first pull to 32 degrees total and hit right at 450hp on the first pull and just a tick over 500 lbs-ft.
