A-904 issue with reverse #1240143
05/26/12 06:23 PM
05/26/12 06:23 PM
Alliance, Ohio
V
Valiant_Showoff Offline OP
V
Alliance, Ohio
Developed a weird problem last night at the track. In reverse it acts like it's binding, or like it's still partially in 1st trying to go forward too. All forward gears and neutral are normal. First noticed something unloading the car at the track, but thought it was just because I was parked slightly down hill didn't give it a second thought. Then at home unloading it is really pronounced. Something is jacked with with reverse in my reverse manual valve bodied A-904.
Any ideas what it could be?
THANKS
Re: A-904 issue with reverse [Re: Valiant_Showoff] #1240144
05/26/12 10:02 PM
05/26/12 10:02 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Forward clutch plates are toast and not releasing when you shift into reverse.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: A-904 issue with reverse [Re: Evil Spirit] #1240145
05/27/12 10:18 AM
05/27/12 10:18 AM
Alliance, Ohio
V
V
Alliance, Ohio
Ugh. That's not what I wanted to hear.
Re: A-904 issue with reverse [Re: Valiant_Showoff] #1240146
05/28/12 08:57 PM
05/28/12 08:57 PM
Alliance, Ohio
V
V
Alliance, Ohio
Searching for reasons why I've burnt out my 2nd set of low clutches in 3 years.
If the drive shaft bottomed out on the launch when everything winds up, could that be putting pressure on the clutches and frying them? Not sure how much play I have as the tranny is already sitting on the garage floor, but will be putting it back in to check the spine depth.
Any other ideas?
Re: A-904 issue with reverse [Re: Valiant_Showoff] #1240147
05/29/12 10:17 AM
05/29/12 10:17 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Any other ideas?
No that wouldn't do it.
Re: A-904 issue with reverse [Re: JohnRR] #1240148
05/29/12 01:06 PM
05/29/12 01:06 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I dont think its the front clutches welded together. Reason is when in third gear the front and rear clutches are applied. So when you go into first the rear clutch and the overrunning clutch give you first. If the front clutches are welded you would be in third gear when you put it in drive and not first gear. Sounds like the rear clutches may have a problem to me since it is applied in all forward gears but not in reverse. Reverse is the forward clutch and the low-reverse band applied so if the rear clutch was partly welded together then you would have a two element fight like trying to be in first and reverse at the same time. Ron
Re: A-904 issue with reverse [Re: 383man] #1240149
05/29/12 01:30 PM
05/29/12 01:30 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Ron , the poster above didn't say front clutches , he said FORWARD clutches ...
Re: A-904 issue with reverse [Re: JohnRR] #1240150
05/29/12 04:25 PM
05/29/12 04:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
"forward clutch" is brand-X terminology and is bound to cause confusion on a Mopar forum. Just as bad as "low clutches".
Re: A-904 issue with reverse [Re: John_Kunkel] #1240151
05/29/12 05:26 PM
05/29/12 05:26 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yea dont why brand X cant get it right. I am just so used to calling the front clutch the forward clutch. Thanks for setting that straight. Ron
Re: A-904 issue with reverse [Re: 383man] #1240152
05/30/12 10:11 AM
05/30/12 10:11 AM
Alliance, Ohio
V
V
Alliance, Ohio
Sorry for my poor use of terminology. I'm a tranny novice.
Also forgot to post it's a reverse cheetah valve body.
