wiring help 518 3 wire speedo #1240101
05/26/12 05:23 PM
05/26/12 05:23 PM
Tampa FL
hemibeep Offline OP
hemibeep  Offline OP
Tampa FL
can anyone tell me the correct wiring for the speedo in the 518 tranny. I am converting to electronic speedo, and do not have a diagram for 3 prongs in speedo housing. thanks
Re: wiring help 518 3 wire speedo [Re: hemibeep] #1240102
05/26/12 06:13 PM
05/26/12 06:13 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Pin 3 is an 8 volt power supply from the PCM, pin 2 is ground and pin 1 is the output to the speedo. With the key tab to your right, pin 1 is at the bottom and pin 3 is at the top.
