1969 Charger Assembly Difficulty... #1239634
05/25/12 01:05 PM
05/25/12 01:05 PM
Cali
U
usmuscle Offline OP
usmuscle  Offline OP
U
Cali
I am looking at a 69 Charger in mid restoration. This car is literally 100% disassembled and sitting on blocks... The good part is that all body work has been completed (in primer & ready for paint) and motor & Trans rebuilt. The rest of the parts are original, but in good condition (about 75k easy miles on them) .
Here is my question... I know I could be much more detailed here, but in general would you say I would have a big project ahead of me to get the engine, trans, rear & suspension installed and this Charger in solid driving condition.
I am not worried about the interior or body right now - these are what I am good at.
She will need new brakes and a suspension rebuild. The rear end could be rebuilt while it is out, but she does not currently need it... Would need a new wiring harness too. All components for the (PS, PB, A/C, Alt, Starter... ) engine come with it and are in working condition (75k miles on them).
I am really just looking for an idea of any major mechanical steps or costs I am overseeing here. Your input is appreciated!
Re: 1969 Charger Assembly Difficulty... [Re: usmuscle] #1239635
05/26/12 09:08 PM
05/26/12 09:08 PM
LA & L.A.
MoparPosterChild Offline
LA & L.A.
Assuming your components are assembled and ready for install, it shouldn't be a big deal. If you have access to a lift it'll be easier. You can mate the trans to the motor, mount the motor and all front suspension stuff on the k member and lower the car and bolt that sucker up. Makes it a lot easier to put it all together that way. Rear end is pretty simple, and so is a drive shaft... All assuming you have a lift you can use.
2018 Dodge DEMON #18
1970 Plymouth Duster 406" Stroker
1969 Charger 500" Stroker
1964 Dodge Polara 426 GEN III HEMI
1970 Plymouth Cuda Hellcrate Project car
1974 Dodge Ramcharger Project car
2017 Chrysler Pacifica Limited
2017 Ram 3500
2012 Dodge Caravan R/T
1972 Charger Mopar 392 HEMI Stolen
2008 Challenger SRT-8 Gone
2010 Challenger SRT-8 Gone
2006 Charger SRT-8 Gone
2007 Charger R/T Gone
