valve spring recomendations? #1236150
05/19/12 11:51 PM
05/19/12 11:51 PM
illinois
bigblk66_coronet Offline OP
illinois
Well guys weve come to the conclusion that i more that likely have a bent valve. So time for new springs. Heres what im running....30 over 440 ,292 purple shaft'with stock eddy hesads. What do you guys recomend for springs? I definatley dont want this to happen again....anyone?
Re: valve spring recomendations? [Re: bigblk66_coronet] #1236151
05/20/12 02:08 PM
05/20/12 02:08 PM
illinois
illinois
Anyone?
Re: valve spring recomendations? [Re: bigblk66_coronet] #1236152
05/20/12 03:04 PM
05/20/12 03:04 PM
Comp 924-16's are a good bet for that application--they are about like a 911-16 with an inner spring--about the same pressure just right for that 509 cam --(11-16's or the stock eddy spring will do the job OK but the 924 is the step up
