Re: A833 mopar overdrive 4 speed
[Re: 72sat]
#123607
09/20/08 06:52 PM
09/20/08 06:52 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Yes, they were made. Volare wagons are common donors. It'll fit any A body, m,j, or F body.
They have some down sides too. "third" gear is where fourth gear used to be on the nonOD versions, so Mopar flipped the shift lever to correct the shift pattern. "Fourth" gear is where third used to be so the counter shaft is spinning whn in OD. Since Chrysler floated the countershaft and didn;t bush the aluminum case this tends to cause wear in the case.
Something to look for.
[Re: Greg55_99]
#123612
09/21/08 02:55 PM
09/21/08 02:55 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I had one in my original 77 Road Runner. Damn thing used to stick between gears for no reason. Never did figure out why.
Greg [/quot
your shifter was worn out...
[Re: dogdays]
#123614
09/21/08 08:22 PM
09/21/08 08:22 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
Once the floating countershaft is taken care of, the OD box is no longer the weakest A833.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: CJK440]
#123615
09/21/08 08:53 PM
09/21/08 08:53 PM
Posts: 1,567 Ky
jt4406
Ky
And what must be done to "take care" of it?
Yeah, it's hopped up to over 160...
[Re: jt4406]
#123616
09/21/08 08:56 PM
09/21/08 08:56 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
bush the case where the shaft goes with a steel bushing
[Re: JohnRR]
#123617
09/21/08 09:41 PM
09/21/08 09:41 PM
DaytonaTurbo
Manitoba, Canada
But that only takes care of one end of the shaft. Isn't the other end of the shaft still floating?
[Re: gamagoat6x6]
#123619
09/22/08 05:26 AM
09/22/08 05:26 AM
Posts: 1,567 Ky
jt4406
Ky
I was thinking more along the lines of putting 4 speed guts in an aluminum od case. Would you need to make the bushings and the shaft an interference fit, like the regular iron 4 speeds are? jt
[Re: jt4406]
#123620
09/22/08 07:53 AM
09/22/08 07:53 AM
CJK440
Ansonia, CT
Yes.
Doesn't need to me much intereference, you are just trying to eliminate the clearance.
[Re: DaytonaTurbo]
#123621
09/22/08 07:54 AM
09/22/08 07:54 AM
JohnRR
U.S.S.A.
Did I say how many bushings needed to be installed in that reply ???
The other end has to float to a degree or you couldn't put it together or take it apart easily . But it's not really floating , its a SLIP fit instead of a LIGHT PRESS FIT . but you can put a steel bushing at the other end also but hone it so the shat slides thru .
YMMV
