Re: Disc brakes: All the math that you never wanted to know
[Re: feets]
#1235239
05/19/12 12:44 AM
05/19/12 12:44 AM
Posts: 151 Plano, TX
68440fish
Plano, TX
where engineers begin frothing at the mouth
Mechanical advantage of the lever at the pedal, area ratio from the master to the caliper, lump capacitance of the fluid system / materials, torque on the wheel from the braking force, coefficient of friction at the pad rotor interface dependent on: brake pad material(s) - rotor material - rotor surface condition - pad surface condition - temperature - humidity, reaction torque from the tire road interface, coefficient of friction at the tire interface as a function of the slip ratio.. nooooo... let it goooo...
OK Kevin, I think I am OK now...
--------------------- Michael AS in Automotive Technology (1990) ASE Certified Master Tech (1991) BS in Mechanical Engineering (1997) MS in Mechanical Engineering w/ a concentration on Dynamic Systems and Controls (2005)
[Re: 68440fish]
#1235240
05/19/12 12:47 AM
05/19/12 12:47 AM
68440fish
Plano, TX
Anyone want to see the bond graph representation of a torque converter?
Oh... never mind...
Michael
Plano, TX
68 Barracuda Notch Pro Patina
[Re: 68440fish]
#1235242
05/19/12 02:05 AM
05/19/12 02:05 AM
Posts: 27,475 So Cal
autoxcuda
So Cal
Interesting - be nice to go out and slowly press the pedal with someone turning each wheel to see if this is indeed what happens. The only way around this would be separate master cylinders and a balance bar, you could then tune it to your liking. ...
On of the advantages to dual masters with balance bar setup. We've done that very test on our circle track cars. We've caught cars with rears that grab first or at the same time.
[Re: 68440fish]
#1235243
05/19/12 03:05 AM
05/19/12 03:05 AM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Michael, I am aware of most of the stuff you listed but didn't want to get into that stuff. It would make the post totally useless for most folks. Also, when I was referring to the movement of the 4 brake pads, I meant the front brakes. The rear brakes were not addressed in the post. I didn't want to go there due to the different proportioning valves in use. Again, I believe the stuff I dumped out there will be good enough to get someone in the general ball park. Obviously, the brake torque calculation shows a perfect scenario where the real world will see the number cut by as much as 65% with the use of poor quality brake pads. Sometimes it's just fun to fiddle around with numbers.
[Re: Uhcoog1]
#1235244
05/19/12 10:54 AM
05/19/12 10:54 AM
Posts: 3,704 MICHIGAN
DynoDave
MICHIGAN
Excel file is available for download here:
http://www.3gduster.com/brakes.html
Enjoy!
When I suggested in the other thread that it would be nice if this was all in an excel spreadsheet, I didn't think anyone would actually do it! I was thinking of trying to do it myself, but it would have taken a week, and I still would not have gotten it right.
Thanks to both of you for all the time you have put into this. This sheet has been downloaded, saved, and backed up for future reference.
[Re: DynoDave]
#1235245
05/19/12 11:11 AM
05/19/12 11:11 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
one bit of math missing here.
relationship of piston stroke in the M/C versus pedal ratio.
Someone here thinks less leverage is less stroke at the M/C
[Re: feets]
#1235249
05/19/12 07:40 PM
05/19/12 07:40 PM
Supercuda
About to go away
About to go away
up yours
I understand all that, but it' not as obvious as it might need to be for some.
Anyway, one other thing to consider when using your formulas is the capacity of the m/c and the needs of the calipers. Not enough volume out of the M/C and the calipers will not do the job, which is what I think FD had for a problem.
[Re: Supercuda]
#1235251
05/19/12 08:18 PM
05/19/12 08:18 PM
feets
Senior Management
Senior Management
Irving, TX
Again, go back and play with the numbers. You can see how far the calipers move with different size master cylinders as well as the pedal force required to generate enough brake torque.
It won't magically tell you everything you want to know. Playing with it and reading all of the results will help you understand what is going on.
Again, it's not the final word in brake info. Instead, it will get you in the ball park assuming you read and understand the info presented.
[Re: DoctorDiff]
#1235253
05/19/12 11:35 PM
05/19/12 11:35 PM
feets
Senior Management
Senior Management
Irving, TX
I think we bore that out in the math. The 15/16" master worked fine once he put the booster back in.
[Re: feets]
#1235256
05/19/12 11:56 PM
05/19/12 11:56 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
The manual 15/16" master cylinder wasn't likely to blame, since I also had trouble with the other two manual units that I tried. The 15/16" unit I have on the car NOW with the power booster is an iron unit spec'd for a 75 Dart with power brakes.
Something wierd was happening and I still don't know what is to blame.
[Re: hooziewhatsit]
#1235258
05/20/12 12:17 AM
05/20/12 12:17 AM
Supercuda
About to go away
About to go away
up yours
When you decrease the pedal ratio, you increase the stroke in the M/C. Power brakes systems use less pedal ratio, therefor more stroke at the MC for a given pedal travel.
Same bore M/C going from manual to power sends out more volume for a given pedal travel.
That's what is different.
