340 pan rail markings
#12344
07/05/04 01:56 PM
07/05/04 01:56 PM
Posts: 3,623 Millinocket, Maine
JonC
Millinocket, Maine
I have capital "D"'s stamped on the oil pan rail on my 340, what do they mean?
11B40
Re: 340 pan rail markings
[Re: JonC]
#12345
07/05/04 01:59 PM
07/05/04 01:59 PM
I was told those stampings represent the bearing clearances, A is tighter than B is tighter than C is tighter than D. On my 87 318 I have some stamped AA the rest are A.
Steve
[Re: JonC]
#12346
07/05/04 02:39 PM
07/05/04 02:39 PM
Posts: 25,894 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The letters stamped on the pan rail are the measured bore size so the assembler would install the correct size piston.
Due to the tight fit of factory pistons and production tolerances, each finished bore was measured and given a letter disignation of its size; the pistons were also sized accordingly.
For example, an "A" or "B" bore would be slightly under spec, a "D" or "E" bore would be slightly over spec and a "C" would be right on .
