Predator help
#1233598
05/15/12 05:27 AM
05/15/12 05:27 AM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
I know there are not many of you guys out there. I'm trying to tune my new combo and would like some advice. Header size, converter stall, gear, carb size, shift point? My combo is dragster, 1840#s, 604CI, one carb, Marcella manifold, 15.75-1, 520cfm flow on intake. Still working on the tune up and somewhat struggleing. Any help would be appreciated.
Re: Predator help
[Re: hemi-itis]
#1233601
05/15/12 12:46 PM
05/15/12 12:46 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
Well I think you know my thoughts. Let it eat. Put that other carb ob, loosen the convertor and spin it up a bit more. But I dont have one, still on the fence. Oh yeah I am working on getting that video up. If I had any computer skills at all it would probably be easy. But since I dont it is kind of like me building a nuclear bomb, or cutting womens hair
Re: Predator help
[Re: Al_Alguire]
#1233602
05/15/12 01:42 PM
05/15/12 01:42 PM
camastomcat
Salt Lake City
Al, I kinda worried about spinning it up with the oil pressure thing. I am talking to that friend of mine that does converters. He said something about a new type of sprag that locks, and when I get back from Germany, I'll take a look at doing that. I've also heard that a 4.30 gear might help. You know me Al, I won't be happy till it is running like it should. On the have I contacted Steve Gill question, Steve has been dealing with other things lately, and I'm trying to leave him alone for now.
Re: Predator help
[Re: camastomcat]
#1233603
05/15/12 02:02 PM
05/15/12 02:02 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
The very Best TC you can buy hands down is ATI,but Hughes may be the Best in setting up a TC for a Big engine dragster. I have done my Home Work on TC for dragsters and Hughes seems to the best. They not only make & sale them but run them in their own Big engine dragsters.
My small engine had some oil pressure problems & runs the same pump and pan as my Big engine which has no problems,so I have done a lot of research on not just the oil pans but pumps and lifters as well. Let me know what your problems are and if nothing else I will be happy to share what I have learned.
PS I went through the same problems with the tune up in my dragster,for some reason they want a different tune up that what a door-car runs.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
Re: Predator help
[Re: jamesc]
#1233606
05/16/12 10:44 AM
05/16/12 10:44 AM
Posts: 1,049 San Jose Ca.
boatracer572
San Jose Ca.
Hey Tom, I have a very good idea what your oil psi. Problem is, had the same issue when I put my first predator mill together. give me a call. Tony
Re: Predator help
[Re: boatracer572]
#1233607
05/16/12 12:20 PM
05/16/12 12:20 PM
MRMOPAR622
Sweet Home Alabama
If his problem is not from lack of oil in the pan,due to not enough or the baffle not keeping what oil is left in the pan trapped over the pick up I would be interested in knowing the problem also. The main problem with the Big block Mopar engines is in the oiling systems. Almost every engine failure on the big blocks are from rod breakage,due to lack of oil which cause's a bearing to spin and takes out the rod. PS it may be next year but if nothing happens I am going to either buy or build a Predator engine.
Re: Predator help
[Re: boatracer572]
#1233608
05/16/12 01:21 PM
05/16/12 01:21 PM
Posts: 341 Highland beach Fl
poisondart2
Highland beach Fl
Hey how about letting everyone know so the folks looking to buy them know the problem before the purchase !
