Race car brake question
#1232916
05/13/12 07:42 PM
05/13/12 07:42 PM
Posts: 20,212 Park Forest, IL
slantzilla
Park Forest, IL
I am going to use an NOS stock '88 disc/drum M/C on the Daytona. It has the factory discs on front and 10" drums on the rear. Will I need to reinstall the residual valves in the lines that were on the car when I got it? IIRC it has a 10# for the rear and 2# for the front. I do not know what the M/C on the car when I got it was originally off of. It was junk anyway. Thanks! Dennis
Re: Race car brake question
[Re: Crizila]
#1232924
05/14/12 09:42 PM
05/14/12 09:42 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I wouldnt put the adjustable prop valve on the rear line... its used to take the spike out if you hit the pedal hard... skinny fronts would just skid if you hit the pedal hard... the pressure will equalize after a bit of time... but by then you not on a skike any longer....the slicks have more stopping power over skinny fronts
