OT sanden A/C compressor info......... #12324
07/01/04 11:26 PM
07/01/04 11:26 PM
Alton, IL
Dakota_Don Offline OP
Alton, IL
for those u who need or will be doing an A/C upgrade or conversion from rv-2 ect to the sandens
here are a few web sites with the sanden A/C units
such as the SD508 and the SD7 (aka SHORTY )
http://www.sanden.com/index.html
http://www.freezonerb276.com/Clutch.htm
http://www.babcox.com/editorial/us/us4016.htm
http://www.blendair.net/test.html
http://www.autoaircompressors.com/sandencomp.htm
http://www.freezonerb276.com/Compressor.htm
http://www.compressor-intl.com/compressor1.htm
http://www.aircoparts.com/COMPRESSORS.html
this one is the best, u can look up all makes and it will tell u what compressor, hoe many groove pulleys ect.... so if u need to go to a bone yard u can look at different makes and get the compressor u need
Re: OT sanden A/C compressor info......... [Re: Dakota_Don] #12325
07/02/04 02:48 AM
07/02/04 02:48 AM
Alton, IL
Alton, IL
BTT
Re: OT sanden A/C compressor info......... [Re: Dakota_Don] #12326
07/02/04 03:15 AM
07/02/04 03:15 AM
Löffingen, Germany
The_Mean_Machine Offline
Löffingen, Germany
Good Info.
Thanks Man!
Frank
Re: OT sanden A/C compressor info......... [Re: The_Mean_Machine] #12327
07/02/04 11:42 AM
07/02/04 11:42 AM
Alton, IL
Alton, IL
no problem , thought i would pass it along, since a few people do the a/c sanden conversion
Re: OT sanden A/C compressor info......... [Re: Dakota_Don] #12328
07/02/04 12:44 PM
07/02/04 12:44 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
well I do ac and I have some questions.
does it fit the stock RV2 brackets? Will the stock hoses fit? Is the pulley in the same place.
I'm not really happy about the job I did on my trailduster with the RV2 compressor but then again, I didnt change the expansion valve to a 134 one so that may have a lot to do with it.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: OT sanden A/C compressor info......... [Re: aarcuda] #12329
07/02/04 01:49 PM
07/02/04 01:49 PM
Huntsville, Ala
sparky Offline
sparky  Offline
Huntsville, Ala
General Consensus is the 134 valve does no good.
You saved some $$$
1978 Lil Red Express
