Re: 383 with Stealth Heads in a 1900 lbs car
[Re: smokinwoody]
#1230674
05/10/12 12:09 PM
05/10/12 12:09 PM
Posts: 5,080 organ
maximum entropy
organ
i smell 9s. makes me wanna git a roadster.
[Re: maximum entropy]
#1230675
05/10/12 01:12 PM
05/10/12 01:12 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
My 383 with 312 heads, TRW pop-ups, a Hughes .600" solid cam, tunnel ram with a pair of Holley 750 double pumpers, Torqueflyte, 4.56 gears, 1600 lbs. ran 9.50's like clockwork.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: Slingshot383]
#1230676
05/10/12 01:57 PM
05/10/12 01:57 PM
Triple Threat
Renton Washington
A friend had a 72 Chevelle with your basic 355 in it. Ran 11.70 best. Sold the car roller and stuck the engine in a 225" WB hard tail dragster and its been 9.40 I believe. only change being headers obviously.
You shouldn't have any issue getting a 9 second run out of it.
[Re: 69dart]
#1230680
06/01/12 06:13 PM
06/01/12 06:13 PM
Posts: 260 arizona
stockerbill
arizona
I sold my old arrow with a tired 383,trw 11.5's,mp590,ootb eddy's,glide and 456's no tune up at all and goes 10 teens in phoenix@2100 lbs
[Re: 69dart]
#1230684
06/05/12 10:45 AM
06/05/12 10:45 AM
Posts: 147 Milledgeville, (central) Georg...
Bighead440
Shifted at 7200 running 8.70's on a stockish bottom end 383 - that's awesome! I doubt I'll zing mine that high - probably 6400 tops but you give me high hopes. I'm a bracket racer through and through so I just want something consistent that I can run the piss out of.
I still have the motor, I want to put a Reed solid roller I have in it, with a valvespring swap and a TM6 with a single 850 Holley, then stuff it in a straight axle Gremlin I have... BTW: We swapped this motor for a 471" B stroker with ported Eddy RPM heads and a mild solid-roller cam (274@.050", .645" lift) and only went 8.10s/170mph with the same carbs and intake. Now we have a M1 tunnel ram and 2 x 850 Holleys and it just runs in the 7s, needs more CAMSHAFT... The 3.38" stroke motors love to rev, so my advice is put a set of rods in it and zing it appropriately!!!
[Re: 69dart]
#1230689
12/30/12 06:07 PM
12/30/12 06:07 PM
That looks Wicked!! I love it!!! Lets see a pix of that FED Light Weight Cars--gotta love them!
[Re: 69dart]
#1230690
12/30/12 06:52 PM
12/30/12 06:52 PM
dartman366
Mt. Vernon, Ohio
So my little roadster is getting a full make over this winter including new engine, trans, wheels and paint. The lil' 383 had some major issue and ended up spinning a rod bearing after just a few more runs. The fact that it ran 6.40's is amazing because the cam had wiped lobes, 2 rings were messed up during install which gouged the block and the head gaskets were leaking. It was just a big mess and all as a result of rushing to get it together. The new engine is being machined and assembled at Mann Performance. Its still a 383 but this time it has eagle rods, billet main caps and a slightly larger cam. The builder expects it to run low 9's but I'll be happy with 9.70's.
I have finished the new paint and have a few more hours of polishing before we can start putting it back together. Hopefully everyone appreciates the retro muscle-car theme inspired by the amazing art work of Bruce.
If the actual car looks like the pic then it's going to look killer Shaun, and should run great too.
[Re: 69dart]
#1230701
04/15/13 10:47 AM
04/15/13 10:47 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Got a few more passes on the new combo yesterday. Had a great day - made it to 3 cars and ran 6.23 several times shifting at 5800. I think there is some more in there with a jet change and cranking up the shift point.
5800...you are leaving a bunch on the table.
[Re: MR_P_BODY]
#1230703
04/16/13 03:43 PM
04/16/13 03:43 PM
Posts: 37 Pataskala,Ohio
DartDoll
Pataskala,Ohio
For his "wifes" sake I am glad he shifted at 5800 for the first major weekend out. Track just wasnt completly there due to the cold and wind and he defintalty got lose several times going down the track. The car looks amazing and I am so proud of all the work and dedication he has put into the car since this entire thing started last September. Cant wait to finalize the template to get that 383 billboard on there. Glad to have it back to all mopar and get running in the Mopar races again. Hopefully get the Challenger out there and get some sweet shots of the cars sitting pretty next to each other! Meg
His Car-1933 Dodge Roadster-383 BB
My Car-1974 Dodge Challenger-340 SB
