Re: why a 4 prong balast?
[Re: Mr.Yuck]
#123003
09/19/08 09:43 AM
09/19/08 09:43 AM
Posts: 2,826 NY usa
540challenger
NY usa
Just oredered my engine harness for my 70 Charger. it has electronic ingniton, guy said something about the harness has been modified and I'll need a 4 prong balast. I have some at home but I've never used one and the MP elect ing distrib kit comes w/ a 2 prong...any reason why?
Stock mopar electronic ingn came with a 4 prong. The modified harness has the connentors for the 4 prong installed. As it would "IF" the factory would of had made it.
If you order a stock engine harness for the points set up then you can just use the 2 prong as just have been to convert over with the kit mopar and others sell.
[Re: Mr.Yuck]
#123005
09/19/08 09:56 AM
09/19/08 09:56 AM
Posts: 2,826 NY usa
540challenger
NY usa
Yeah I was thinking about that as the distrib kit has a harness in it. I got the modified one because it's ready to go. So I guess I'll need to use one of those bulky 4 prong units.
Yup get the 4 rpong and you are set.
[Re: Mr.Yuck]
#123006
09/19/08 10:02 AM
09/19/08 10:02 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Not modified just designed after the first years of the Mopar electronic ignition where one side is the start circuit and the other side of the ballast is the run circuit. The later 2 prone ballast has only the run circuit.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: Mr.Yuck]
#123016
09/20/08 10:44 AM
09/20/08 10:44 AM
Posts: 2,537 God's Country Maryland
GODSCOUNTRY340
It depends on your ECU. If you have the 4 peg ECU you only need the 2 prong ballast. If you have the 5 peg ECU you need the 4 prong ballast.
