how much gained from shallow staging
#1229708
05/08/12 06:42 PM
05/08/12 06:42 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Just curious how much et and mph can be gained through shallow staging, do slow cars pick up more than faster ones? Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
Re: how much gained from shallow staging
[Re: deaks]
#1229709
05/08/12 07:02 PM
05/08/12 07:02 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The size of the front tires is going to have a major effect on that... cant say if a slow car or fast car with everything being the same will do better... if all was equal I would think the percentage of change would be the same or very close
[Re: hugo]
#1229712
05/08/12 08:36 PM
05/08/12 08:36 PM
MR_P_BODY
does a bigger tire hrlp you?
Bigger tire gives you more roll out... longer time in lights
[Re: deaks]
#1229715
05/08/12 11:21 PM
05/08/12 11:21 PM
MR_P_BODY
Are you asking shallow vs deep staging or shallow vs a normal staging
[Re: MR_P_BODY]
#1229716
05/09/12 09:16 AM
05/09/12 09:16 AM
deaks
robin hood country
Either, i was just curious, as to peoples findings. I was prompted to ask the question after reading the setup instructions on the portatree. Cant beat the good old internet. LOL Mick
[Re: deaks]
#1229717
05/09/12 09:48 AM
05/09/12 09:48 AM
Posts: 293 Kansas City Metro
mbogina
Kansas City Metro
A general rule of thumb is that 1 inch of rollout is roughly equivalent to .01 ET difference. this will vary slightly with slow cars vs fast cars, but still in the ballpark.
Be a Rebel- Break the Laws of Physics!
[Re: mbogina]
#1229718
05/09/12 10:00 AM
05/09/12 10:00 AM
deaks
robin hood country
So if i was to flicker the second stage light with a 27" tyre, what would that approximately equate to. Mick
[Re: deaks]
#1229719
05/09/12 10:16 AM
05/09/12 10:16 AM
MR_P_BODY
You would have to measure up 3" from the ground then measure the length at 3" up to see how long the tire is in that area... pressure in the tire also makes a difference... low pressure has more tire in the lights... high pressure has less... also you need to check the front end to see if you have any stagger in it... with most chassis cars we add about 3/4" to 1" of stagger to the front tires... we usually set the right side tire back
[Re: MR_P_BODY]
#1229720
05/09/12 10:57 AM
05/09/12 10:57 AM
mbogina
Kansas City Metro
This is not a tough deal to measure yourself-set a flashlight blocked 3" off the ground on the drivers side of the car, roll the car forward until the light is completely blocked by the tire. Make a reference mark on the ground. Roll the car forward until the flashlight beam just starts to be visible past the rear of the rearmost tire, make another reference mark. Measure the distance between the reference marks, that is your maximum rollout available. If that distance exceeds the distance between the prestage light and the stage lights at the dragstrip, you will "turn the top light out" during final staging.
