Re: Installing Battery In Trunk Wire Size ? [Re: therocks] #1228493
05/08/12 09:58 AM
05/08/12 09:58 AM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
https://www.cloudelectric.com/default.asp
I just bought some 2/0 guage fromt his place.
Look at the ev welding cable. More flexable then std wire.
Re: Installing Battery In Trunk Wire Size ? [Re: krw71ragtop] #1228494
05/08/12 11:00 AM
05/08/12 11:00 AM
Az
Crizila Offline
Crizila  Offline
Az
I'm at the point where I have to decide if this is going to be a race car or street car.
Know that feeling! Last November I was racing a car that weighted well over 3900 lbs. I am now racing the same car at 3425 lbs. I need to have an attic sale . I'm still suffering from weight loss aholic withdrawl symptoms - ( weight difference between 0 and 1 gauge wire !)
Fastest 300
Re: Installing Battery In Trunk Wire Size ? [Re: Crizila] #1228495
05/08/12 11:18 AM
05/08/12 11:18 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
this is how i mounted the switch in my dart, the 1/4 stainless rod comes out the bumper jack slot
Re: Installing Battery In Trunk Wire Size ? [Re: Crizila] #1228496
05/08/12 11:40 AM
05/08/12 11:40 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I would rather over kill on wiring than have the
AMP/voltage loss... if the volts are up it MIGHT
make more power to cover up the weight gain...JMO
Re: Installing Battery In Trunk Wire Size ? [Re: MR_P_BODY] #1228497
05/08/12 12:51 PM
05/08/12 12:51 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Based on ship weight from Grainger on 100ft, 2/0, 1/0 and 1 gauge wire. The weight per foot on each is:
2/0 = .49
1/0 = .39
1 = .31
So a 10 foot run of each wire won't vary more than about 2 pounds. Not real significant.
Re: Installing Battery In Trunk Wire Size ? [Re: RobX4406] #1228498
05/08/12 01:09 PM
05/08/12 01:09 PM
Az
Crizila Offline
Crizila  Offline
Az
2/0 = .49
1/0 = .39
1 = .31
True, I checked it - but if you are using #0 welding cable, the weight difference will be significant.
Fastest 300
Re: Installing Battery In Trunk Wire Size ? [Re: Crizila] #1228499
05/08/12 01:16 PM
05/08/12 01:16 PM
RobX4406 Offline
RobX4406  Offline
2/0 = .49
1/0 = .39
1 = .31
That is welding cable weights.
http://www.engineersedge.com/copper_wire.htm
I'll still take a heavier fine strand wire that weighs 4# per 10 ft than save some weight on a 2.5# per 10 ft inferior wire.
