Re: Mopar Action article 9 1/4
[Re: Crizila]
#1227945
05/06/12 11:34 AM
05/06/12 11:34 AM
Posts: 121 mid-mich
turboplymouth
mid-mich
They put some special c-clip Eliminator bearing in it which required a retube with special housing ends. Used a trutrac diff. Apparently you can use 8.75/Dana adjustable bearings with custom tubes also.
'72 Scamp, 3500#, 440, S400, blowthrough, meth. inj.
9.78 @ 139 so far at 12 psi, 11.00 @ 131 on real street tires.
[Re: turboplymouth]
#1227946
05/06/12 07:12 PM
05/06/12 07:12 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
I was thinking of cutting the ends an using a sealed Bearing BR20 with the appropriate housing ends. Wonder why the retube it.
[Re: Crizila]
#1227950
05/07/12 11:56 AM
05/07/12 11:56 AM
Posts: 8,016 Polson, MT
DoctorDiff
Polson, MT
Sounds like you're dealing with the wrong company. Forged steel 1350 U-bolt yoke kit $70 Custom 31 spline axles $385 pair assembled Billet housing ends $70 pair Crush sleeve eliminator kit $25 Please E-mail for more information doctordiff@gmail.comThanks, Cass
[Re: DoctorDiff]
#1227952
05/07/12 01:01 PM
05/07/12 01:01 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
Thanks,
Cass
How bout a spool?
[Re: goldmember]
#1227953
05/07/12 01:35 PM
05/07/12 01:35 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Lots of 11 second 4,000 lb Dakota's running a stock 9 1/4 axle. even a handful of 10 second trucks with the factory axle. Moser shafts are only a few hundred bucks.
**Photobucket sucks**
[Re: Crizila]
#1227954
05/07/12 03:58 PM
05/07/12 03:58 PM
MattW
Ontario Canada
I've been running my 9 1/4 for about 5 years now with no problems ( mid 11 second car ). Heard all the "C" clip horror stories - and maybe some are true . Obviously thats a drawback to using that diff ( along with the fact that they don't make a spool for it ). Otherwise, it's a very strong diff and would easily handle a 10 second car IMO. Just seems to me that the cost to have it modified for bearing retained axles would be more than just switching to a Dana or a Ford 9"? I'm in the process of updating my drive shaft to use 1350 joints ( replacing the existing 7260 joints - which have also been trouble free for 5 years )and gotta make a diff decision.
I like the 9 1/4 rear plenty out there but do not know if it is worth the hassle. Seems like Cass has some good info.
[Re: Crizila]
#1227956
05/07/12 08:24 PM
05/07/12 08:24 PM
goldmember
Gainesville,FL
A spool would really make this a good unit,very common and inexpensive. My friend ran one for years in his bracket Stude (SBM powered) with good results. Recently put a Dana in it but would have stayed with the 9 1/4 if a spool was available.
[Re: goldmember]
#1227957
05/07/12 08:36 PM
05/07/12 08:36 PM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
A spool and some pro gears would make that thing a pretty nice unit and cheaper than a 9" and lighter than a Dana.
[Re: DoctorDiff]
#1227959
05/08/12 09:16 AM
05/08/12 09:16 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
No one carries an off-the-shelf 9.25" spool.
Supposedly, Summers Bros will make a custom spool for $500-$600, however.
Or in a pinch if the posi unit is built like the one I had in a Dana years ago, (two halves, bolts together, friction plates) you can figure out just how thick an extra shim it takes to in effect, lock it up. In the case of the Dana, it took one cut up 3lb coffee can lid!
[Re: gregsdart]
#1227960
05/08/12 10:01 AM
05/08/12 10:01 AM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I ran one weleded in a 4000 lb truck for years, It ran 11.50's with a big block on a 150 shot. Still have it sitting out back!
67' charger 499 RB
10.57 at 127
[Re: gregsdart]
#1227961
05/08/12 12:49 PM
05/08/12 12:49 PM
70Cuda383
Marysville, O-H-I-O
why not just weld the spiders together?
