tail panel trim 70 Cuda #1227666
05/05/12 05:46 PM
05/05/12 05:46 PM
Iowa
TX9AAR Offline OP
TX9AAR  Offline OP
Iowa
I m trying to put the tail panel trim on my car and am having a hard time with the plastic clips below the plastic plug is next to impossible to put in. Any advice would be great.
Re: tail panel trim 70 Cuda [Re: TX9AAR] #1227667
05/06/12 12:13 PM
05/06/12 12:13 PM
Rhode Island
jml19621 Offline
jml19621  Offline
Rhode Island
Had the same problem, carefully make the hole larger using a round file. Paint was the main culprit. Also when pushing the trim on use lithium grease. Just my opinion.
Jeff
Re: tail panel trim 70 Cuda [Re: jml19621] #1227668
05/06/12 12:39 PM
05/06/12 12:39 PM
Iowa
TX9AAR Offline OP
TX9AAR  Offline OP
Iowa
Thanks I didn't think about using a round file my friends first thought was to drill the holes out a little but I like the file idea better.
