Once again, the great refrigerant debate
#1226610
05/03/12 01:53 AM
05/03/12 01:53 AM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
ASSuming the small amount of pressure I found in the Imperial's A/C system is a sign the car will actually hold a charge, what refrigerant should I use?
I have 4 cans of R12. This system holds 4 lbs 6 oz (dual evaporator two row condenser). In the perfect world that's 5 cans. In the real world, I'll never get full cans in there because of equalizing pressure. I could pick up a 5th can off Craigslist for less than $30.
I have 134a readily available and dirt cheap at work. I did convert my 92 D250 but can't get it to hold a charge for very long.
I know a bunch of "drop in" refrigerants are out there, many of them based on butane or other volatile gasses.
I'd sure hate to dump a the R12 in the system and have it blow out through a leak or rupture.
BTW... I brought home a Robinair vacuum pump to pull down what's currently in the system and verify it will hold. Once that's done, I'll try to evacuate the remaining compressor oil and replace it with new stuff.
Re: Once again, the great refrigerant debate
[Re: feets]
#1226611
05/03/12 02:06 AM
05/03/12 02:06 AM
Posts: 4,848 Memphis
HemiRick
Memphis
If it will hold a vacuum, that's a good sign it will hold the freon. From my understanding the old style compressor doesnt pump R136a for long before dying. Since you have the R12 all ready I;d use it, assuming the system will hold a vacuum for 12 hours.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#1226612
05/03/12 05:15 AM
05/03/12 05:15 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
put the can in a bucket of hot water when you install the R-12. I guarante all of it will go in.
I am truckless..
[Re: HemiRick]
#1226613
05/03/12 08:37 AM
05/03/12 08:37 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
Empting the cans is why you charge thru the low side.Thats why it called suction.That being said I changed a bunch to 134 at work.Most there were no problems.I like to change all the O rings I can get to.Than and a new dryer and adding the proper oil.Then with a good machine you can add a partial charge with dye and most now have sealers in them.If no leaks fully charge.I still have a new can of 12 in the garage I had for my 57.I changed it to 134.Ran it for 5 years.It did have a small leak so I added about a pound every spring.Rocky
Chrysler Firepower
[Re: markrr]
#1226615
05/03/12 11:40 AM
05/03/12 11:40 AM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
I went with the Envirosafe Industrial 12a when I put my Dakota together. Works great, blows mid 30's at the center vent. And it's compatible with all of the oils. http://autorefrigerants.com/co00033.htm$180 plus free shipping for the equivelant of 63 lbs of R12 made the choice pretty easy. Yes, it's hydrocarbon based but think about carrying 20 gallons of gas around. I'm not worried about it. Tech info: http://autorefrigerants.com/Envirotechnical.htm
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
[Re: herkamer]
#1226616
05/03/12 01:22 PM
05/03/12 01:22 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
There is a shop in town that swears by the HC freons and I have replaced many condensors that exploded as a result. Don't use any HC freon! Pull a good vaccume, if it holds, fill with your R-12. Heating the cans is a good way to get the last little bit out of them. I ususlly dangle them on the ex manifold. Always atatch them to the low side and after the first can is in start it and turn on the compressor so it actually pulls lowest preasure on that low line, then heat the can to get the most out of it. PS technically the low side is not really a suction, it still will have much higher preasure than the atmosphere, it is just not as high as the high side
[Re: HotRodDave]
#1226617
05/03/12 02:14 PM
05/03/12 02:14 PM
Posts: 5,875 communist bloc of new jersey
jamesc
Freon is a Dupont trademark for chlorofluorocarbon refrigerant.
the vast majority of refrigerants are "HC".
as an example R-12 is dichlorodifluoromethane, methane is a HC (natural gas). r-134a is tetrafluoroethane, ethane is the next heaviest hydrocarbon to methane.
incidentally some of these can thermally decompose into phosgene gas...which just happens to be a chemical weapon
[Re: rhad]
#1226620
05/03/12 03:43 PM
05/03/12 03:43 PM
Andrewh
i changed over my 92 dakota a couple of yrs ago,i DID NOT drain out the old oil,just added the new type oil and 134,NO problems,no leaks
it isn't leaks that are the issue. the new oil turns the old dryer material into goo as I understand it.
at some point it may clog something if it circulates.
[Re: feets]
#1226621
05/03/12 10:47 PM
05/03/12 10:47 PM
feets
Senior Management
Senior Management
Irving, TX
Good news. The car appears to have held a vacuum. Since my gauges only go up and don't have a vacuum scale, I didn't bother with them. I drew a vacuum on the car for 20 minutes this morning. When I got home from work I connected the vacuum pump again. It started working hard immediately. I poked the schrader valve stem on the high side and the vacuum pump rpm shot up. After drawing a vacuum again I went ahead and connected my gauges to the high side. It drew the needle below zero. I put the pump away but left the gauge on the car. I'll check it in the morning to see if it reads the same. If so, it's time to change the compressor oil and charge it.
