double roller cover fit issue.440 #1226155
05/02/12 07:34 PM
05/02/12 07:34 PM
michigan,usa
W
woody02 Offline OP
woody02  Offline OP
W
michigan,usa
i had a single roller timing gear set,but when i tried to fot that cover on the double roller timing set it wont fit? what cover do i need to fit a double roller timing set.oh, 440 engine.
Re: double roller cover fit issue.440 [Re: woody02] #1226156
05/02/12 08:24 PM
05/02/12 08:24 PM
Amherst,NY
challengermike Offline
Amherst,NY
i have always used a stock cover with a double roller. I did have to leave off the oil deflector that go's on the crank though.
Re: double roller cover fit issue.440 [Re: challengermike] #1226157
05/02/12 10:18 PM
05/02/12 10:18 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Never had an issue with the deflector or a stock cover ... YET ...
Re: double roller cover fit issue.440 [Re: JohnRR] #1226158
05/02/12 10:36 PM
05/02/12 10:36 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
...Same here, no issues, even with dual idler gear drives
Re: double roller cover fit issue.440 [Re: DAYCLONA] #1226159
05/03/12 10:46 AM
05/03/12 10:46 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Check to make sure everything is installed properly.
Something's not right
Re: double roller cover fit issue.440 [Re: roadhazard] #1226160
05/03/12 10:52 AM
05/03/12 10:52 AM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
I just installed mine with a double roller and the oil slinger and no problems.
Re: double roller cover fit issue.440 [Re: bobs66440] #1226161
05/03/12 11:24 AM
05/03/12 11:24 AM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Likely the crankshaft gear isn't seated all the way.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: double roller cover fit issue.440 [Re: DAYCLONA] #1226162
05/03/12 11:56 AM
05/03/12 11:56 AM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
cam gear has a dish to it, make sure its not on backwards
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: double roller cover fit issue.440 [Re: 440lebaron] #1226163
05/03/12 10:40 PM
05/03/12 10:40 PM
Amherst,NY
Amherst,NY
Maybe it was just the deflector i had. Either way you flipped it it would hit either the cover or the gear. Ever since then i have just tossed them to the trash and havn't had a problem since.
