Re: Fan belt won't stay on at high rpm
[Re: Hemi ragtop]
#1224669
04/30/12 08:16 AM
04/30/12 08:16 AM
Posts: 21,487 It's a dry heat
gtx6970
It's a dry heat
The belt is a repro without the i.d. notches ie: modern fan belts. Does anyone have a suggestion?
Put a quality belt on it will probably cure the problem
[Re: twinscrew698]
#1224670
04/30/12 09:37 AM
04/30/12 09:37 AM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
I don`t have a Hemi,but i had the same problem with my 400! What i did was take a straight edge to the crank pulley and the pulleys to make sure they was lined up even tho they looked like it the power steering pump was off just a little so i shimmed up the pump with washers behind the brackets and it cured my problem! Just an idea that might help ya!
I had the same thing, Duster kept tossing the belt right at the finish line at the track. Turned out things were just a little off.
[Re: Hemi ragtop]
#1224673
04/30/12 12:06 PM
04/30/12 12:06 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Well once it throws a belt it must be thrown away they take a little twist and keep throwing. Check alignment Then Tighten belt warm right up no high revs then re tighten belt they stretch first time warmed up. then make sure not does not loosen again.
[Re: Dodgem]
#1224675
04/30/12 07:56 PM
04/30/12 07:56 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Check alignment
That is correct as I found out years ago once a belt is thrown it will keep coming off even if you fix a problem. I would definetly try a new good brand belt. Ron
[Re: Hemi ragtop]
#1224678
04/30/12 11:33 PM
04/30/12 11:33 PM
Posts: 12,861 Gloucester,VA STOP MOVING HERE
RangerDan440
actually I think I can see the problem-youre using a dual groove pulley alternator designed for an AC car when you should be using a single groove-the dual groove pulleys are aligned differently.
68 Valiant 408 69 Charger 318 69 Cougar 351W 70 Torino GT 351C 71 Country Squire 351W 71 Road Runner 440+6 71 Satellite sedan 318 73 Duster 318 73 Challenger 383 77 Grand Prix 455 83 Malibu 9C1 383 84 Delta 88 403 87 Grand National 96 Ram 360 09 Crown Vic 10 Challenger R/T M6 15 Challenger Hellcat M6
[Re: gtx6970]
#1224680
05/01/12 01:22 PM
05/01/12 01:22 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
The repop belt is the problem...Junk...
MB
[Re: Hemi ragtop]
#1224681
05/01/12 02:29 PM
05/01/12 02:29 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Where are the cords in the belt? Cheap belts have them in the middle, good belts have them towards the top or fat side of the belt.
Finding good belts these days is a chore, 40 yrs ago all belts where made with the cords on the fat side.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#1224686
05/02/12 07:22 AM
05/02/12 07:22 AM
Posts: 984 Tennessee
Hemi ragtop
Tennessee
The belt is a Quanta. It is beginning to look like that is the culprit.
[Re: Hemi ragtop]
#1224687
05/02/12 11:27 AM
05/02/12 11:27 AM
RapidRobert
A guy on here used a pencil laser pointer laid in the groove and used shims/flat washers to get his front to rear pulley alignment dead on. Also make sure the PS pump housing/pulley is parallel to the crank/wp pulleys
[Re: 68jim]
#1224688
05/03/12 07:37 AM
05/03/12 07:37 AM
Hemi ragtop
Tennessee
Factory Hemi will use a dual pulley on the alternator. I'm not sure though if the one he is using (A/C??) will have the same offset to match up with the repro pulleys.
I got an original? HEMI pulley and compared the belt depth with the pulley that came on the replacement alternator. The belt rides deeper in the groove on the original. Does the pulley press on and off like the p/s pulley?
[Re: Hemi ragtop]
#1224689
05/03/12 11:39 AM
05/03/12 11:39 AM
Posts: 1,029 Southeast Virginia
68jim
Southeast Virginia
The pulley can be swapped out with an original one (2095095). You do need a special fixture to remove it - don't try a generic puller. There are a few on eBay currently. eBay link to pulleyI'm running all original pulleys on my hemi with some Mopar brand fan belt I bought probably 15 years ago. My motor has seen 6K rpms many times now with no belt issues other than re-tightening after the initial stretch. Jim
