DUAL exhaust pipe size on 273 commando engine ? #1224182
04/29/12 01:58 PM
04/29/12 01:58 PM
Wi.
65_gt_rag_402 Offline OP
Wi.
early abody dougs d450 headers1 5/8" tubes .. 2.5 collector , Stock 65 dartcharger 273 .... Question is>>> what size headpipes off the headers would work the best with this engine? I have an old set up 2.5" headdpipes dynomax ultraflo muffs and 2.25 tails . do you think the 2.5 head pipes are tooo large ? or will work just fine .
This little engine does not have a lot of torque as you all know...... so I do not want to take all the bottom end away with big tube pipes.
65 DART GT RAGTOP mopars "AWESOME" 360 magnum stoker 402 Engine !!!!!!! ROCKS !!!!!!!!!! 11.0's on pump gas .
Re: DUAL exhaust pipe size on 273 commando engine ? [Re: 65_gt_rag_402] #1224183
04/29/12 04:19 PM
04/29/12 04:19 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I would stick with the stock single Commando exhaust from the headers back. You'll have to fab into the single exhaust. That's what I have with the exception I'm running a Flowmaster instead of the stock muffler.
Re: DUAL exhaust pipe size on 273 commando engine ? [Re: 65_gt_rag_402] #1224184
04/29/12 06:19 PM
04/29/12 06:19 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
2" would be fine, and no bigger than 2 1/4 if you ever plan to hop it up a little during a rebuild. Most people notch the passenger side of the torsion bar crossmember and transmission mount to keep the pipes tucked up neatly on both sides. Be sure to get the muffler shop that makes your new system to use aluminized pipe. See if they will let you brush the welds and treat them with Eastwoods manifold coating while it's all fresh and up on the rack.
Re: DUAL exhaust pipe size on 273 commando engine ? [Re: JDMopar] #1224185
04/29/12 11:13 PM
04/29/12 11:13 PM
Central NC
gch Offline
gch  Offline
Central NC
2" would be ideal with a good flowing muffler.Consider a 2.5 mandrel bent single for ease of fitment and less weight.
