Oil pickup tube depth #1223444
04/28/12 07:02 AM
04/28/12 07:02 AM
Ohio
fiddlestix Offline OP
Ohio
I am setting up a 493 stroker with a 1/2" pickup tube, a Milodon 30930 pan, girdle and windage tray. What is the recommended distance from the bottom of the pickup to the bottom of the pan?
Thanks guys.
Re: Oil pickup tube depth [Re: fiddlestix] #1223445
04/28/12 07:12 AM
04/28/12 07:12 AM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
Is it the stock type with the metal guard covering half the screen? If so, I've heard everything from touching the bottom to 1/4" up. I put mine in just barely touching the bottom because it has a space between the guard and the screen. If there's no guard, around 1/4"-3/8" seems to be the average standard.
