Page 3 of 3 1 2 3
Re: Dual 2.5" vs Single 3" exhaust [Re: OzHemi] #1223259
05/03/12 11:27 PM
05/03/12 11:27 PM
Its a TRAP!
DARTH V8Я Offline OP
Oh No!! I just had a moron attack!
Its a TRAP!
Thanks for the tip, what do you do on the core side?
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Dual 2.5" vs Single 3" exhaust [Re: DARTH V8Я] #1223260
05/03/12 11:32 PM
05/03/12 11:32 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I ran AN hose from the water pump to the firewall, then an AN bulkhead fitting, and then used AN pushlock style fittings under the dash side to heater hose to run to the aftermarket a/c-heater box.
Re: Dual 2.5" vs Single 3" exhaust [Re: OzHemi] #1223261
05/03/12 11:52 PM
05/03/12 11:52 PM
Its a TRAP!
Its a TRAP!
WOW! Thats a clean install! I was just gonna flip the core 180 degrees and use the rubber hoses. BUT I'm digging your setup.
Re: Dual 2.5" vs Single 3" exhaust [Re: DARTH V8Я] #1223262
05/03/12 11:57 PM
05/03/12 11:57 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I took my time and tried to make it pretty tidy at least. I ran the heater hoses under the intake...not really something you can do with the factory F body intake of course.
I ran them up under the A/C compressor then through the bracket. You can kinda see in this pic
Page 3 of 3 1 2 3
