Frayed battery feed #1222784
04/26/12 08:23 PM
04/26/12 08:23 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I have a frayed battery feed at my alternator. I would like to find a way to replace the ring connector but still keep the stud covered up. I could probably replace the connector and then slide a carburetor vacuum plug over the stud but there would still be some exposed metal.
Any ideas?
A bunch of electrical stuff in the river city today.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Frayed battery feed [Re: cdstl] #1222785
04/26/12 08:46 PM
04/26/12 08:46 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
clip it off and head over to NAPA. if they don't have the exact boot terminal they'll have something close without the need for a jury-rig job.
Re: Frayed battery feed [Re: mikemee1331] #1222786
04/26/12 09:10 PM
04/26/12 09:10 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Thansks Mike, didn't know that finding one would be that easy.
Chuck
Re: Frayed battery feed [Re: cdstl] #1222787
04/26/12 09:26 PM
04/26/12 09:26 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
NAPA's rock! and the older the store the better!
Re: Frayed battery feed [Re: cdstl] #1222788
04/27/12 12:02 PM
04/27/12 12:02 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
OK. Napa came up with a big zero for this little connector. Does anyone know what the proper name for it would be. Beginning an online search right now.
Re: Frayed battery feed [Re: cdstl] #1222789
04/27/12 02:53 PM
04/27/12 02:53 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Found them. Alternator hot-wire insulator. Year One and Little Detroit Restorations has them. $7 to $9.
Re: Frayed battery feed [Re: cdstl] #1222790
04/27/12 07:48 PM
04/27/12 07:48 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i'm shocked that NAPA didn't have something you could have used that had an insulator cover. sorry to lead you astray!
Re: Frayed battery feed [Re: mikemee1331] #1222791
04/28/12 09:04 AM
04/28/12 09:04 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
No worries, they had the field wires.
