Street fuel pump
#1222654
04/26/12 05:00 PM
04/26/12 05:00 PM
Posts: 1,505 TN
SCATPACK 1
TN
I have used the Search feature and did not find my answer. I would like to know what fuel pumps you are running on the street and an occasional drag strip session or motocross in the parking lot. I have a manual pump that I could use, but I don't think it will be enough for my engine set up. (Aluminum head 572 Hemi, roller cam 266@ 50 and 650 lift, 1050 Dominator carb, 4 speed, Dana 4.10 Track pack) What electric pumps haveyou used fo rextended periods? Are they quiet enough to listen to the radio or talk on the phone. (I went thru 2 Holley electrics last season and both were extremely noisy) Do you have to run a pressure regulator or is it built in? Thanks for the help Jerry
Old Geezer Racing
Re: Street fuel pump
[Re: SCATPACK 1]
#1222655
04/26/12 05:06 PM
04/26/12 05:06 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Carter 'Street Pump' mechanical pump. 6 psi. On the engine since '99.
You'd want the race pump, I don't remember the psi.
I don't know anything about any electrical pumps, other than the cheap one I bought for the Ramcharger is quiet. But I didn't need it, so I now use it for syphoning gas out of the trucks to put in another truck or boat so I ccould go fishing when I was out of money.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: amxautox]
#1222656
04/26/12 05:18 PM
04/26/12 05:18 PM
Posts: 1,505 TN
SCATPACK 1
TN
I have the Carter pump and the Holley pump. Neither are strong enough to do what I want. And they both limit you to a 5/16 line max in and out. I have checked Mancini's and all of the ususal places online for a really good race manual pump. there just aren't any for Mopars with 1/2 fuel lines. You can get them for a Ford or Chevy round track engine, but nothing for a Mopar big block. I thought of buying one of the big block Chevy pumps ($140) and retro fitting the billet parts to my Hemi pump. But then I would have $250.00 in a manual pump. I was hoping to not have to do that and I am not sure the Chevy pieces would even match up.
Old Geezer Racing
