diff between the 4 and 5 pin ECUs #1222557
04/26/12 11:49 AM
04/26/12 11:49 AM
Kent, WA
triple_green Offline OP
Kent, WA
can someonoe explain the difference between the 4 pin and 5 pin ECUs and when they were used?
Thanks!
3X
68 Charger, 383 HP console auto, spring green, stock restoration
Re: diff between the 4 and 5 pin ECUs [Re: triple_green] #1222558
04/26/12 12:11 PM
04/26/12 12:11 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Re: diff between the 4 and 5 pin ECUs [Re: triple_green] #1222559
04/26/12 03:14 PM
04/26/12 03:14 PM
P
Paul_Fancsali Offline
P
You can replace a 5 pin with a 4 pin But not vice versa.
Re: diff between the 4 and 5 pin ECUs [Re: triple_green] #1222560
04/26/12 04:13 PM
04/26/12 04:13 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
5 pin ECU's use a 4 pole ballast resistor
4 pin ECU's use a 2 pole ballast resistor
