Re: Smoking drum brakes
[Re: 67DeLuxe]
#1222408
04/26/12 12:16 AM
04/26/12 12:16 AM
Posts: 905 SD
zrxkawboy
SD
Probably a rusty/sticky parking brake cable that didn't release.
It's Swifty! Swifty, you toad sucker!
[Re: 67DeLuxe]
#1222409
04/26/12 12:26 AM
04/26/12 12:26 AM
Posts: 7,664 IN
ahy
IN
I'll suggest step by step trouble shooting and checking. The original problem could be simply the shoes themselves falling apart, mechanical binding or a problem with a stuck slave cylinder. One side only kinda rules out the master.
When you replace the shoes, do the slaves also. Clean and lube the self adjusters and (carefully) lube the contact points inside the drum. When done, and while still on stands, check it out. Adjust the brakes for slight drag first, bleed then check. Apply the service brakes firmly then release. Check for any binding. Apply the parking brake, release and check. Penetrating oil (PB blaster, liquid wrench ect.) is "first aid" for sticking parking brake cables. If they are really rough, Inline tube and others sell good re-pops.
[Re: dogdays]
#1222412
04/26/12 03:05 PM
04/26/12 03:05 PM
Posts: 4,179 California
mickm
California
Smoking drum brakes? Bad for your health.
R.
damn, beat me to it!
