power to manual brakes #1221697
04/24/12 03:10 PM
04/24/12 03:10 PM
NC
P
phil4161972 Offline OP
P
NC
I have a 72 cuda with factory power disc brakes. I was thinking about changing to manual brakes due to the current installed cam not having alot of vacuum. What all is needed to make the change to manual brakes? Just a different master cylinder?
Re: power to manual brakes [Re: phil4161972] #1221698
04/24/12 03:49 PM
04/24/12 03:49 PM
United states wisconsin
bigblockbryan Offline
when i did mine on my fury i just took the power booster off and it it bolted right up
Re: power to manual brakes [Re: bigblockbryan] #1221699
04/24/12 03:51 PM
04/24/12 03:51 PM
NC
P
P
NC
I would assume you have a really hard brake pedal like that?
Re: power to manual brakes [Re: phil4161972] #1221700
04/24/12 10:57 PM
04/24/12 10:57 PM
Mid Michigan
Coronet-R/T-Rag Offline
Mid Michigan
Just did a power drum to manual disc swap on mine. Search for the Disc-o-tech article from Mopar Action. It's got lots of good info. You do need to swap the master cylinder and I'd use one with a small bore to ease pedal pressure. I went with a 15/16 but I would like to try a 7/8.
