Sealing Header Bolts #1221539
04/24/12 10:56 AM
04/24/12 10:56 AM
Westphalia, Meeeeeshigan
MIRADAMANia Offline OP
I have a header bolt that won't seal. What have you had the best luck with?
Re: Sealing Header Bolts [Re: MIRADAMANia] #1221540
04/24/12 11:11 AM
04/24/12 11:11 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Dab of Ultra Copper/Orange Permatex RTV hasn't let me down yet. Assuming coolant is leaking.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Sealing Header Bolts [Re: MIRADAMANia] #1221541
04/24/12 11:13 AM
04/24/12 11:13 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
1.use as many ex mani studs as you can... 2. If you can't use the long header bolts and use a dab of sealer or teflon tape and you should be G2G...
Coming soon!!!!
Re: Sealing Header Bolts [Re: Mr.Yuck] #1221542
04/24/12 03:41 PM
04/24/12 03:41 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
As stated above, and I've also used anti-sieze with no problems on aluminum race heads. I use anti-sieze on all exhaust fasteners anyway, as well as on anything exposed to coolant, and on wheel stud threads.
Re: Sealing Header Bolts [Re: topside] #1221543
04/24/12 06:46 PM
04/24/12 06:46 PM
I have used this Permatex Aviation Form-A-Gasket before without problems but one bolt is leaking this time. I'll give the copper rtv a try.
Thanks!
Re: Sealing Header Bolts [Re: MIRADAMANia] #1221544
04/24/12 07:01 PM
04/24/12 07:01 PM
might grab a new header bolt too
Re: Sealing Header Bolts [Re: RapidRobert] #1221545
04/24/12 10:29 PM
04/24/12 10:29 PM
fort worth,tx
txterry2 Offline
super gas
txterry2  Offline
super gas
fort worth,tx
Red high temp silicone
Re: Sealing Header Bolts [Re: RapidRobert] #1221546
04/25/12 08:25 AM
04/25/12 08:25 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
and mabey a little longer
