Page 1 of 3 1 2 3
Adjusting valve lash #1221458
04/24/12 07:38 AM
04/24/12 07:38 AM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
I have the decal that states to set the engine at TDC and then rotate in 90º increments. How many turns should I give the adjustment screw on the rocker AFTER it mates with the cup of the pushrod?
How many threads should be showing on the underside of the screw where the ball is. Is it between zero and two threads?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Adjusting valve lash [Re: Pyper70] #1221459
04/24/12 08:29 AM
04/24/12 08:29 AM
Idaho
LaRoy Engines Offline
Idaho
More information is required to give a good recommendation.
The preload of a hydraulic lifter will be specified by the lifter manufacturer, some want .030-.040" some .000-.004", some .060". Who's lifter and part number are you using. Or is it a solid lifter?
The number of threads showing is also dependant on the rocker manufacturer. One to two is generally okay but some don't show any threads when set up correctly and some say back the adjusting screw into the rocker body until it stops and turn it out one turn, then measure for pushrod length, allow for lash/preload, buy the correct pushrod length, install and set load/lash.
Re: Adjusting valve lash [Re: LaRoy Engines] #1221460
04/24/12 09:09 AM
04/24/12 09:09 AM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
eesh...I think the lifters are Isky (only because the Cam is Isky) The rockers are Crane Ductiles.
Re: Adjusting valve lash [Re: Pyper70] #1221461
04/24/12 01:50 PM
04/24/12 01:50 PM
I like and use the method that follows,rotate the motor over in the normal rotation and then set the intake valve when the ehxaust valve just starts to open, after setting the exhaust rotate the motor over until the intake valve opens all the way and starts to close, up from botton about a 1/3 to 1/2 way up then set the intake rocker . If your using hydraulic lifters back the adjsusters off enough to get some up and down movement between the pushrod and rocker, slowly tighten the adjsuter until you get zero lash, tighten 1/4 turn and try that. Drive the car and see if you like that, then do it again and try 1/2 turn of preleoad, decide from there
Re: Adjusting valve lash [Re: Pyper70] #1221462
04/24/12 02:22 PM
04/24/12 02:22 PM
Idaho
Idaho
Then do as Cab suggests. Under the circumstances that is what I would do.
Re: Adjusting valve lash [Re: Cab_Burge] #1221463
04/24/12 02:52 PM
04/24/12 02:52 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Thats how I used to do my Slant except I used .010 / .020 feeler gauges and it was good to go. Gonna try to do this with a remote starter to kick the engine over....Might just take off my clutch fan and see if I can get more of a fine turn out of it...
Thanks fellas
Re: Adjusting valve lash [Re: Pyper70] #1221464
04/24/12 03:08 PM
04/24/12 03:08 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
Removing plugs will allow you to turn it over a lot easer.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: Adjusting valve lash [Re: Pyper70] #1221465
04/24/12 05:06 PM
04/24/12 05:06 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
If you know what the actual pre load is,put a 3/8 fine thread bolt and nut in a vise,run the bolt flush with the head of the nut,put a dial indicator on the bolt,count turns to get preload you need then turn adjusters same amount after removing lash..
Re: Adjusting valve lash [Re: Pyper70] #1221466
04/24/12 05:17 PM
04/24/12 05:17 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
the way I do it with a hydralic cam, is to watch the plunger in the lifter, take all the lash out and count how many turns it takes to bottem out the plunger without anything moving. Then I usally will only run about 1/3 of that in preload.
Has never failed me yet and I have rebuilt many different motors.
It don't matter to me who makes what, just that you have the proper preload. Every motor is different even the same make, so I don't see how anyone can tell you "how many turns"?
Like cab said, 1/2 turn of true preload, you can't go wrong just as long as your on the true heel of the cam. Got to be sure...
Re: Adjusting valve lash [Re: 62maxwgn] #1221467
04/24/12 05:39 PM
04/24/12 05:39 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
3/8 fine thread is 24 threads per inch , that comes out to .041666666 per thread , a bolt has 6 flats , if one full rotation of a nut is one thread , not sure if it is ??? , then each flat is worth .00694444 , make it an even .007 ...
When I did the latest preload in effort to quiet a noisy comp XE grind I physically put every lifter on the base circle opposite the nose on every lobe of the cam and adjusted preload, took a long time but it worked out very well.
Re: Adjusting valve lash [Re: JohnRR] #1221468
04/24/12 05:47 PM
04/24/12 05:47 PM
Cincinnati, Ohio
Cincinnati, Ohio
3/8 fine thread is 24 threads per inch , that comes out to .041666666 per thread , a bolt has 6 flats , if one full rotation oof a nut is one thread , not sure if it is ??? , then each flat is worth .00694444 , make it an even .007 ...
Yes I do each one separately, not hard to do on a engine stand. Much tougher in the car I bet?
Re: Adjusting valve lash [Re: Challenger 1] #1221469
04/24/12 05:48 PM
04/24/12 05:48 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
not really , just harder on the back due to leaning over the fender. The only way to really get a good view of the lobes is with the intake off though.
Re: Adjusting valve lash [Re: JohnRR] #1221470
04/24/12 05:56 PM
04/24/12 05:56 PM
Cincinnati, Ohio
Cincinnati, Ohio
not really , just harder on the back due to leaning over the fender. The only way to really get a good view of the lobes is with the intake off though .
Definitely, it's the only I have done it.
Re: Adjusting valve lash [Re: Pyper70] #1221471
04/24/12 06:23 PM
04/24/12 06:23 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
check this out Pete
Re: Adjusting valve lash [Re: JohnRR] #1221472
04/24/12 06:36 PM
04/24/12 06:36 PM
1/2 turn on a 3/8-24 thread adjuster would be .021" (.0208")
Re: Adjusting valve lash [Re: RapidRobert] #1221473
04/24/12 06:42 PM
04/24/12 06:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
yes and ???
Re: Adjusting valve lash [Re: JohnRR] #1221474
04/25/12 09:47 AM
04/25/12 09:47 AM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
I have the rockers soaking in 30wt right now. Its about 345pm here. Buttoning up the exhaust to the manifolds, draining the oil and filling it back up with a my new non-Fram filter
Hopefully by the time that is all finished it will be about 530pm here and I can call Todd at Comp Wedge who made the Harlands for me. Judging from the little time I tinkered with the pushrods and the rocker I may have about 3-4 threads showing. If I can run it that way and I get a green light then I will go ahead with it. If not...then I will wait for another car show, its not that important.
Harland instructions say to use Zinc additive in the oil. I have never seen anyone selling zinc additive here or oil with a high zinc content. Is it critical to the first time usage?
I am running Castrol 20w-50 because frankly I have 5 gallons of it and oil here is next to the price of gold here.
Re: Adjusting valve lash [Re: Pyper70] #1221475
04/25/12 10:18 AM
04/25/12 10:18 AM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
The normal lifter pre-load talk goes a bit out the window if you start talking about the anti pump-up lifters. Most manufacturers recommend that these types of lifters be set to 0 (zero) pre-load. The procedure is to basically locate the lifter on the base of the cam lobe, losen up the rocker arm screw, then slowly tighten up. As you do this, rotate the pushrod between your fingers...as soon as you feel it catch/slow down you are basically sensing that all clearance has been taken up. With the anti pump-up lifter you leave it there...that is because the lifter is meant to act as if it was solid lifter, the anti pump-up is meant to prevent the oil build-up in the body of the lifter at high RPM and therefore the normal take-up of the clearance which may cause the intake valve to remain off seat (instead of closing) and therefore a myriad of other problems.
I've been using these in my 360 motor...
Re: Adjusting valve lash [Re: Pyper70] #1221476
04/25/12 10:22 AM
04/25/12 10:22 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
How many threads does the instructions for the HS rockers call for ? One other issue you need to pay attention to is oil getting to the cup , some adjusters have to be in a certain spot for the oil to make it to the cup.
Re: Adjusting valve lash [Re: Pyper70] #1221477
04/25/12 12:29 PM
04/25/12 12:29 PM
very critical. Many options to choose from but yes you need enough zinc
Page 1 of 3 1 2 3
