Re: 5.2L Magnum Intake Plenum Gasket- how to test
[Re: Dartslantsix]
#1217166
04/17/12 08:03 AM
04/17/12 08:03 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
usually it'll be wet with oil. might not be oil puddled up on the bottom, but just wet. you could also have an O2 sensor going south affecting the engines fuel trims.
but, the use of oil is a big indicator too. now that you changed the plugs, how are they looking?
**Photobucket sucks**
[Re: Dartslantsix]
#1217170
04/17/12 11:31 PM
04/17/12 11:31 PM
Posts: 949 Klamath Falls, Oregon
Dartslantsix
Okay. I just tested the truck. I could not see any movement on the paper either sucking in or pushing out. This is over the oil fill hole. Second thing I tried was pulling the hose connected to the PCV and the one on the other side that goes to the air cleaner. I put my thumbs over both hose ends to see if there was pressure. There was pressure on the non-PCV side, but none on the PCV side. I'm not sure if the valve itself prevents pressure during certain conditions. Here's the TSB, I think I'll try using a gauge to make sure I was hearing pressure and not vacuum. http://www.dodgeram.info/tsb/2000/09-05-00.htm
