radiator question #1216808
04/16/12 02:19 AM
04/16/12 02:19 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
I found a good deal on a northern radiator, its a tripple pass. Would this be a good option for a 572 hemi? Should I get mounts welded on to fit my B-body? Tim
Re: radiator question [Re: astjp2] #1216809
04/16/12 10:17 AM
04/16/12 10:17 AM
Andrewh Offline
Andrewh  Offline
found a dual pass and did that.
basically, I took measurements on the old rad, split the mouting bracket on the driver side so it would clear the battery.
then measured where they would have to weld it to make the holes line up.
fit where the old 26inch did.
Re: radiator question [Re: Andrewh] #1216810
04/16/12 05:41 PM
04/16/12 05:41 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Would a tripple pass radiator be enough for a Hemi or would the flow be restriced too much? Tim
Re: radiator question [Re: astjp2] #1216811
04/16/12 05:54 PM
04/16/12 05:54 PM
Andrewh Offline
Andrewh  Offline
someone else needs to answer that. I think it is based on hp rating though as to how much cooling you need.
as for restrictions, I think that was always do to number of cores not passes. but again, not sure.
4secondsflat.com the guy that answere there seems to be very knowlegeble on these things.
