rear end whining??
#1216713
04/15/12 11:33 PM
04/15/12 11:33 PM
Posts: 1,944 woodcrest, CA
magnum440d100
woodcrest, CA
Today coming from church, I heard a screech/grind coming from the rear end. I was maybe 1/4 mile from my house, so I drove it home. Disconnected the driveshaft, and it turned with great difficulty. Pulled drums off, threw the tire back on to help turn it, and it still turns hard. This is an 8 3/4 which I thought were indestructible wondering what should I look for when it comes apart? Any common problems? This is my only ride, and I kind of want to get parts before I pull it apart.
Re: rear end whining??
[Re: CUDA8U]
#1216716
04/16/12 01:59 AM
04/16/12 01:59 AM
magnum440d100
woodcrest, CA
which case is it 741,742,489?
no idea...all I know is its in a 72 d100. its an 8 3/4 with sure grip. thats all I know.
How do I tell what case it is??
[Re: magnum440d100]
#1216718
04/16/12 12:38 PM
04/16/12 12:38 PM
RapidRobert
If OE it'd be a 489. Might score an open 489/471/472 for cheap to get you up & running then you can fix yours at your leisure. Just make sure the one you buy if you go this route has the same u joint, only 2 choices 7260 or 7290 so it'll be an easy bolt in. You may go with the better clutch type sure grip (742/741) rather than the 489 if yours is too badly damaged. Holler how it turns out
[Re: dogdays]
#1216720
04/16/12 01:56 PM
04/16/12 01:56 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I'd check to make sure the pinion nut is tight, if not then you got bigger problems.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: magnum440d100]
#1216722
04/16/12 02:38 PM
04/16/12 02:38 PM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
'72 with a cone type , I would have another chuck ready to swap in , make sure you get all the old METAL FILLED oil out.
Luckily it's a 2whl drive and you can just throw anything in .
[Re: CUDA8U]
#1216724
04/16/12 03:17 PM
04/16/12 03:17 PM
JohnRR
U.S.S.A.
the stamp will be on the drivers side front of diff.,hopefully you have the 742,it has bigger components.
Unless someone changed it it's a 489 or a 741 .
[Re: JohnRR]
#1216725
04/16/12 08:30 PM
04/16/12 08:30 PM
dogdays
Right. Assuming it is a stock rear end, it's either a 741 or 489. Assuming it's a stock rear end it has a cone-type Sure Grip that was called a SpinResistant by Borg-Warner who manufactured it. When Chrysler sold it to the public in a vehicle they called it Sure Grip no matter what style it was, that was their trade name. Now, if you were buying a new replacement it would be an Auburn as they manufacture the cone type these days.
So unless your '72 truck is a factory bigblock, it has a 741 housing with a cone-type Sure Grip in it. If it was a factory big block it would have a 489 case with a cone type Sure Grip.
As the cone type wears it grinds off little particles of metal which circulate with the oil. So what JohnRR was saying is that no matter what else you do to your rear end, you should plan on cleaning out all of the old oil and particulate.
Now, on to the "stamped" versus "cast" numbers. Casting numbers are cast into the part, NOT STAMPED. Stamped numbers usually go on a surface that has been machined off and are pressed into the metal in the stamping process. Casting numbers are part of the mold into which the molten metal is poured and are there when the part is taken out of the mold. Axle housings or carriers or pigs or whatever else you call them, are castings. As such they have casting numbers. These are on the forward side of the housing going in ghe same direction as the pinion. Occasionally there is a housing without a casting number but this is rare.
R.
And to complete the trifecta, forged rods have FORGING NUMBERS! Now I'll stop whining.
[Re: magnum440d100]
#1216726
04/17/12 02:09 AM
04/17/12 02:09 AM
magnum440d100
woodcrest, CA
havent had time to look yet, sorry guys. i'm pretty sure its a stock rear end. the original owner wasnt known for his mechanical abilities, and my grampa nor I has ever swapped it out. thanks for the knowledge guys I got the next couple days off of work, and I'm doing a motor swap to earn some extra funds (GM 2.2 in a 96 s10...FUN) I hit up the pick a part today and got a sway bar among some other goodies, and am going back for more tomorrow. I have to get some stuff for the 2.2 swap and as a side I am stopping and getting more parts for my truck lol
